Which channel amp?
Old Jan 1, 2009 | 09:53 PM
JCL's Avatar
JCL
Default Which channel amp?
i have a slim 8" pioneer sub 500w max and a set of energy enc650cv speakers
size is a factor because i want to hide the amp inside the sub box and the sub itself is no more than 3" high.
price range 0-200
i was looking at the alpine mrp f300.
suggestions?
Old Jan 2, 2009 | 05:01 AM
fcm's Avatar
fcm
Old Fart
Default Re: Which channel amp?
What is the continuous, [RMS] power handling of the speakers and the sub, max power does not mean a lot.
You can not install the amp inside the sub box, it needs air circulation for cooling. 94
Old Jan 2, 2009 | 01:42 PM
JCL's Avatar
JCL
speakers:
Mfr. Part Number: ENC650CV
Converts to Components Yes
Frequency Response 65Hz – 23KHz
Impedance 4 Ohms
Impedance Rating 4 OHMS
Included In Box Grills, Hardware
Mid Range Size 6.5 in
Mid Range Style CNC Cast Aluminum
Mounting Depth 3.25 in
Power Handling 75 Watts
Product Dimensions 16.51(W) x 22.08(H) x 43.18(D) cm
Product Warranty 1 Year Parts & Labour
Product Weight 3.76 kg
Recommended Power Range 25 - 150 Watts
Sensitivity 91dB
Speaker Size 6.5 in
Speaker Type 2-Way
Super Tweeter Style Not Provided By Manufacturer
Tweeter Size 0.75 in
Tweeter Style Soft Dome
Woofer Material Woven Glass Fibre
Woofer Surround Material Ribbed Elliptical
sub:
http://www.pioneerelectronics.ca/POC...S-SW841D?tab=B
hope that helps.
Old Jan 2, 2009 | 08:05 PM
mrdeadman's Avatar
They let me pick
Do you want to amp your speakers as well?
I wouldn't even mount an amp on the sub box much less in it. Electronic parts are fairly sensitive and the constant pounding from the sub is hard on them. Like fcm said, it will overheat if it doesn't have air cirulation.
Old Jan 2, 2009 | 10:36 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
your sub is 125w RMS... (NORMAL power) your speakers are 25W.
so.. your looking at maybe a 4 channel, 400w amp. wire each component to the respective 1&2 channels, bridge 3&4 on the sub. you should get maybe 50each speaker, and 100w to the sub.
so you want to recommend a amp for your 3 speakers.
http://www.crutchfield.com/p_236TN40...tml?o=v&tp=115
that amp is 200 bucks on crutchfield.. but im sure it can be found cheaper online somewhere... also hiding it under a seat isn't that difficult at all.
45w each speaker, and 150w bridged at 4 ohms.. sound perfect for your setup.
Old Jan 3, 2009 | 12:59 AM
JCL's Avatar
JCL
ya now im going to mount it under the front seat. so id need a thin one that mtx one should work perfect.
yea i do want to amp the speakers as well.
djhex1_ek4
Audio / Security / Video
12
Oct 1, 2010 06:26 AM
89dohcEF
Jun 22, 2005 04:17 AM
_Bug_
11
May 8, 2004 06:02 PM
ck279
Oct 28, 2003 03:46 PM
JOMO
17
Jun 11, 2003 08:00 PM
