CD player question
Old Aug 7, 2005 | 04:48 PM
B16Acrx90's Avatar
Default CD player question
I was taking my CD player out of my car and I was cutting the wires i think i cut two wires at once and i hear a pop. Im guessing the two wires were the memory and the power wires. Now my cd player wont get any power. I cant figure out what it is. Any help would be greatly appreciated.
Old Aug 7, 2005 | 06:00 PM
fcm's Avatar
fcm
Old Fart
Default Re: CD player question (B16Acrx90)
POP, the sound of a fuse blowing, have you checked both fuses, the radio fuse in the in car fuse box and the backup fuse, [7.5A] in the engine bay fuse box? 94
Old Aug 7, 2005 | 06:47 PM
prelude964's Avatar
Default Re: CD player question (fcm)
Also, don't some cd players have a fuse in the back of them? I know Sony ones do. You might want to check that to see if it's blown.
Old Aug 8, 2005 | 11:14 AM
B16Acrx90's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">POP, the sound of a fuse blowing, have you checked both fuses, the radio fuse in the in car fuse box and the backup fuse, [7.5A] in the engine bay fuse box? 94 </TD></TR></TABLE>
I checked all the fuses they are not blown. Still no power
Old Aug 9, 2005 | 09:21 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Acrx90 &raquo;</TD></TR><TR><TD CLASS="quote">
I checked all the fuses they are not blown. Still no power </TD></TR></TABLE> You will have to check and see if you have power at the HU plug, the red wire should have power when the ign. key is on, the yellow wire should have power all the time.
Cutting the acc. and constant power wires at the same time will not blow a fuse
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Acrx90 &raquo;</TD></TR><TR><TD CLASS="quote"> Im guessing the two wires were the memory and the power wires.</TD></TR></TABLE> That would be the red and the yellow on the aftermarket wire harness, or the yellow/red. [acc.] and white w/yellow or blue stripe, [constant] of the oem radio harness.
If you do not have power on the red and yellow wires of the HU harness, you must have a blown fuse, a bad connection, or you have miswired the harness.
If on the other hand you do have power at the HU plug then make sure, as prelude964 mentioned, that if there is a fuse under the plug, [must unplug the HU harness to see it] that it is good, if there is one and it is good, then you have shorted out something in the HU itself. 94
hdj20
Audio / Security / Video
Nov 26, 2009 07:10 PM
KILLAB17VTEC
Jul 7, 2009 06:24 AM
ProjectCD5
Mar 19, 2009 08:12 AM
4thgenlude
Aug 30, 2004 03:41 PM
crxdriver
Aug 23, 2002 07:11 AM
