car audio troubles !!
Old Oct 20, 2003 | 12:14 PM
zcivicz's Avatar
Default car audio troubles !!
k whenever i change cd tracks i get this weird low freq noise coming out of the speakers. it sounds like interference but with what?? same thing happens when i'm using my cell phone in my car...HU is clarion dxz535 i think, JBL 6.5, mtx amp, ma audio 10"sub. i tried switching cds but no improvement. dunno exactly when it started doing it but i just noticed it couple days ago...can anyone help ? its really annoying!!
Old Oct 20, 2003 | 01:13 PM
Torridcivic's Avatar
Default Re: car audio troubles !! (zcivicz)
Is it a buzzz? For a while I had a problem where you could hear the cd laser motor adjusting, kind of. In between tracks, the worst was from the last track to the first.
Old Oct 20, 2003 | 01:24 PM
zcivicz's Avatar
Default Re: car audio troubles !! (Torridcivic)
yeah man a really LOW buzz...but it seems i only hear it when the sub is connected...maybe its a connection to the amp?? i dunno just throwing in some ideas...i'm really clueless here...pls help!
Old Oct 20, 2003 | 04:45 PM
zcivicz's Avatar
could it be a bad ground ?
Old Oct 21, 2003 | 10:36 AM
zcivicz's Avatar
anyone ? pls ?
Old Oct 21, 2003 | 02:02 PM
rjr162's Avatar
in all honesty it might just be your cell phone. Mine did it with the Alpine deck I had. I'd hear a loud buzzing from my speakers before my phone ever rang, and it only did it if I had my phone in the pocket under the radio (or near it). My guess is when you're chaning tracks, the complete silence from the audio source is allowing you to hear the interference from your cell phone.
Old Oct 22, 2003 | 06:00 AM
zcivicz's Avatar
Default Re: car audio troubles !! (rjr162)
yeah it happens also when i'm not using the cellphone. even if the cell phone wasn't in my car it would still do this. i tried to see if there's a crimp somewhere along the rca cable...i thought i fixed it then later when i went to start it up, it started making that sound again everytime i would change tracks. its really pissing me off ! someone help! someone here's gotta know....
Old Oct 22, 2003 | 06:05 AM
carolinaACCORD's Avatar
you could always replace the RCA's with a new set. I've seen them cause similar problems before. Usually happens with cheap *** cables.
Old Oct 23, 2003 | 11:01 AM
zcivicz's Avatar
Default Re: car audio troubles !! (carolinaACCORD)
yeah maybe its the cheap rca wires...we'll see when i get some rockford cables...i had some stinger cables before and never had a problem with any noises...i hope that fixes it cuz now it sometimes goes away then comes back...
Old Oct 23, 2003 | 11:23 AM
realblag's Avatar
I think you have problems with your headunit. When you change tracks, the radio is supposed to "mute" the rca outputs so you dont hear any grumbling, groaning, hummings noises. If you suspect the rcas are at fault, turn everything on, unplug the rcas at the radio. If the noise is gone, the radio has a problem. If the niose is not gone, the rcas are bad.
Old Oct 23, 2003 | 11:29 AM
4uhataz's Avatar
It could also be the amp for the subs. I'd unplug the RCA's at the amp and if it stops then you know what the problem is.
Old Oct 24, 2003 | 12:06 PM
skunksol's Avatar
Default Re: (4uhataz)
yeah 9 times out of 10 it's the headunit that makes sounds like that...especially if it's being caused by the switching of tracks....
Old Oct 24, 2003 | 03:43 PM
zcivicz's Avatar
Default Re: (skunksol)
hmmm...well for two days now the sound goes away and comes back...i think it might be my headunit...you guys think i should trade it for an alpine cdm 7871 ?? i might have a chance to trade my clarion for an older alpine...but i will try unhook the rca at the amp and see if the sound is still there...thanks guys
Old Oct 27, 2003 | 07:51 AM
zcivicz's Avatar
Default Re: (zcivicz)
well i disconnected the rca at the amp and noise went away. i put it back on, and the noise is back...does this mean my amp is bad? or just the rca output on the amp ?
Old Oct 27, 2003 | 09:34 PM
stockLS's Avatar
are your rca's ran on the same side as the power... ? if so this tends to cause that "pop" ing sound or the fuzzy sound inbetween tracks... if this is the case you will want to run the rca cables down the other side of the car ... also if they are touching near the amp .. buy some wire loom and cover your power wire up .. i have had this problem from time to time when i am running two amps or a x over try that out and see if this cures your problem... the cell phone .. thats another story something new to me!
Old Oct 28, 2003 | 06:14 AM
realblag's Avatar
the rca jacks on the amp are inputs. the amp is going to play what the head unit tells it to. you need to turn the system on, unplug the rcas at the radio, and listen. If the noise is there, bad rca's. if the noise is not there, bad radio.
mike12a
Audio / Security / Video
12
May 13, 2013 12:52 PM
BiG_DeE
Sep 3, 2010 12:21 PM
aznd87
Nov 7, 2006 03:02 PM
JTCdudeman
Apr 1, 2003 11:20 AM
acuraLSSE95
Nov 4, 2002 06:06 PM
