amp connect help
Old May 12, 2013 | 02:23 AM
mike12a's Avatar
Default amp connect help
hi guys i have this cd player and im trying to connected with amp but it dosent come out sound.....it's sound only like a woofer i connect speakers but only bass come out ...the cd player is a sony cdx gt40u
Old May 12, 2013 | 02:55 AM
silkypillows's Avatar
Default Re: amp connect help
what type of amplifier? 1/2/4/5 channels?
Old May 12, 2013 | 04:13 AM
mike12a's Avatar
2 channel
Old May 12, 2013 | 05:49 AM
and you are trying to hook up 1 or 2 subs to this amp or?
Old May 12, 2013 | 09:01 AM
mike12a's Avatar
i dont want sub i want just sound only speakers ..i have try but only sound like sub only bass ....is possible with this stereo or i need a 4 preout stereo?
Old May 12, 2013 | 02:51 PM
edzy's Avatar
those preouts are only for subs
Old May 12, 2013 | 02:54 PM
try adjusting the crossover on the amp if it's initialized. its sounds like it cutting out the frequencies you want to hear.
2 channel amp is generally only good for 2 speakers. when used without subs, it would either be the front door speakers or the rear deck speakers. if you want all four hooked up, you need a 4 channel amp or another 2 channel and front and rear pre-amp outputs from your stereo
Old May 13, 2013 | 02:37 AM
mike12a's Avatar
i want to hook up the rear speaker with the amp and front to leave with the stereo ... with this stereo is possible??
Old May 13, 2013 | 04:00 AM
Yeah, no problems as long as the speakers you intend to amplify can take the wattage.
If you still have problems with your amplified speakers only having bass. ensure your deck is set to send out a "rear" signal and not a "sub" signal - and set your crossovers on the deck and amp(if applicable) to match the Hertz (Hz) range of your speakers. (check owners manuals)
http://store.sony.com/p/Car-Audio-CD...GT40U#features
..the CDX-GT40U offers selectable rear or subwoofer pre-amp RCA outputs for connecting external amplifiers. Set the built in electronic HPF/LPF cr..
Old May 13, 2013 | 05:00 AM
grumblemarc's Avatar
The Grumpiest
Surely this thing came with instructions and that this bit of information was in them.
Old May 13, 2013 | 10:59 AM
mike12a's Avatar
yes i found it i had to turn off the stereo then select what i wanted sub or speaker in the preouts ..thnx for the replay
mike12a's Avatar
i found it thnx for the replay
Old May 13, 2013 | 12:52 PM
edzy's Avatar
whoooooooooooooooooooops
Read that wrong
Outlaw-Hondaz
Audio / Security / Video
Apr 7, 2011 03:55 PM
mpociask
Jun 24, 2004 07:14 AM
malix
Feb 2, 2004 12:44 PM
dcviperboy
Nov 17, 2003 12:16 PM
JLange
21
Sep 19, 2003 01:49 AM
