Alarm?
Old Feb 1, 2007 | 05:02 PM
hondachris1994's Avatar
Default Alarm?
I wanna put another alarm horn on my car, do just jump another power and ground from the other horn, or what is the correct way to do it?
Old Feb 1, 2007 | 05:04 PM
perseverance's Avatar
u can tye another siren to the existing siren output on ur alarm. if u decide to do anymore than you'll need a relay.
Old Feb 1, 2007 | 05:23 PM
Default Re: (perseverance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote">u can tye another siren to the existing siren output on ur alarm. if u decide to do anymore than you'll need a relay.</TD></TR></TABLE>Explain this. u mean just the way I said it in my post? Also could I use my car horn?
Old Feb 1, 2007 | 07:00 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (hondachris1994)
you could use what ever siren that you want and any number of sirens. If you go more then three you are going to need a relay. If you are going to use your horn and its a dei unit you are going to also need anothor relay because the horn signal is negative. Some alarms have a negative horn honk output so you won't need a extra relay for that. What kind of alarm do you have? Just make sure that the siren you use is not a speaker type unit.
Old Feb 2, 2007 | 02:22 AM
I have a K-9 alarm, but can I run it 2 my car horn?
Old Feb 2, 2007 | 09:40 AM
fcm's Avatar
fcm
Old Fart
As has been mentioned Yes you can drive your car horn(s) with the alarms siren output, but a relay is needed, [a horn needs more current then a siren] you would also have to add a "flasher" as siren outputs are a "steady" output, meaning the horn(s) would just come on steady,"HOOOOOOOOOONNNNNNNNNNNNNNNNNNK"
and drain the car batt. pretty quick.
If you want to use the cars horn check and see if your alarm has a horn output. 94
nitewolf
Audio / Security / Video
Aug 5, 2010 07:03 PM
ScareyH22A
Apr 30, 2010 09:49 AM
snapcase318
Oct 15, 2003 10:17 AM
ultimatehonda
Jan 21, 2003 02:43 AM
Blk_prl
Oct 22, 2001 01:02 PM
