Box choice
Old Jan 16, 2011 | 10:59 PM
Fendyc718's Avatar
10 Year Member
Default Box choice
I got a pair of L7s I just got but they didn't come with
Box. I'm looking to buy one or if have to I will make one
But I would like to know is which is a better choice for them
Bought or made. Plus should I go with a sealed box, pored box (single or double). And should I wire them together. Thanks for any help. Plus it's going to be in a trunk of 2001 accord coupe if that makes a difference.
Old Jan 17, 2011 | 12:30 AM
mrmondaynight's Avatar
Default Re: Box choice
what size?
Get one made..ported tuned low
hit up these guys for one http://www.soundsolutionsaudio.com/f...argent-audio/?
Old Jan 17, 2011 | 07:04 AM
fcm's Avatar
fcm
Old Fart
Model of L7 would help.
The L7 will work in a wide range of sealed box sizes but for best results a properly built slot port vented box is best...http://www.kicker.com/sites/default/...cL72008.pdf.94
Old Jan 17, 2011 | 10:25 AM
Fendyc718's Avatar
10 Year Member
I have two 12s not sure of what the model number is but
I have the blackish grey ones not the silver and blue ones
If that helps
Old Jan 17, 2011 | 10:39 AM
wolfy47's Avatar
a ported box for sure...im sure you would be able to find the dimensions/specs of a stock kicker box pretty easy
Old Jan 17, 2011 | 08:52 PM
Fendyc718's Avatar
10 Year Member
Would getting a ported box with it on the side be better then the ones with the ports in the middle of the box. Also with box with ports in the middle should each sub have it's own port or just one port for both
Old Jan 18, 2011 | 12:59 AM
One port
Old Jan 18, 2011 | 05:38 AM
fcm's Avatar
fcm
Old Fart
On same surface as subs. 94
Old Jan 20, 2011 | 11:47 AM
Fendyc718's Avatar
10 Year Member
i have been looking online for some boxes and i came across these wondering if it was any good this the model number of the box Atrend E12DVK
and heres the link:
http://cgi.ebay.com/ebaymotors/ATREN...item45f7e831b7
Old Jan 20, 2011 | 05:13 PM
Don't buy a prefab box
get one made
Old Jan 20, 2011 | 05:55 PM
Fendyc718's Avatar
10 Year Member
where would i be able to get a box custom made at. could i just go to sound shop and have them do it or do i have to go some where else to get one made. also is there a site where i can get a custom box made and shipped out or no.
Old Jan 20, 2011 | 07:49 PM
Kev2010's Avatar
get one made
Correct.
Prefab leak a lot of air.
Old Jan 21, 2011 | 05:16 AM
I see you went right over the FIRST reply
Old Jan 21, 2011 | 06:02 AM
fcm's Avatar
fcm
Old Fart
and heres the link:
Sounds like a pretty good box, 1" face with the rest 3/4" cut out is exact, and the box is specific to the sub also a good price.
I am no fan of "pre-built" sub enclosures, most are generic, poor quality, thin material ans often particle board instead of MDF, with speaker cutouts that are not exact.
In this case I would be inclined to get the box, add some sealing, silicon to the seams and a wood sealer to inside of box. 94
Old Jan 21, 2011 | 06:28 AM
Bet it's tuned high, though(40's)
Also, the box is 1.7 per and the minimum is 1.75. Who knows if they took account for sub and port displacement.
Old Jan 21, 2011 | 08:09 AM
mhart's Avatar
how close are you to Clearwater?
Old Jan 21, 2011 | 08:21 AM
mhart's Avatar
Atrend is all made oversea, wood cost about 30 a sheet, have some local make it for you, i suggest Audio Experts in Clearwater, if you talk to Luke, tell him Matt Hart sent you.
Old Jan 21, 2011 | 01:03 PM
Fendyc718's Avatar
10 Year Member
Alright thanks for all the advice and suggestions. And no I'm not close to Clearwater I'm in broward county but thanks again for the recommendation
Old Jan 21, 2011 | 07:18 PM
http://www.floridaspl.com/forums/index.php
Old Feb 3, 2011 | 08:45 PM
Fendyc718's Avatar
10 Year Member
i have been looking to get a new amp as well and iv heard that hifonics amps are pretty good. iv seen the Brutus series a lot. if i was to get on what would be best. getting two to run each sub or one amp for both.
black92DA
Aug 2, 2010 08:43 PM
shibby
Audio / Security / Video
Dec 16, 2003 08:12 PM
schwinn
Jun 19, 2002 10:47 PM
