Wiring question?
Old Feb 3, 2011 | 08:43 PM
suds1485's Avatar
Default Wiring question?
Im about to install a new stereo system in my car. i want to do the big three upgrade and all of my ground straps i just have a few questions.
1. When doing the positive battery to the alternator im supposed to leave the factory wire in place and just run a new wire?
2. considering that im running a hot wire from the alternator to the battery shouldn't i fuse it?
3. With the fuse should i it close to the battery like the amp kit or closer to the alternator?
4. What rating fuse should i use?
Im going to use 4 gauge wire for everything. This is going in a 2001 civic ex thanks in advance.
Old Feb 5, 2011 | 08:05 AM
fcm's Avatar
fcm
Old Fart
Default Re: Wiring question?
If you upgrade a power lead, replace the original, a fuse is not required on the alt. charge line, a 4ga charge line is way overkill, your alt. does not produce 150A, [capacity of 4ga cable].
When beefing up the grounds you can add a ground lead and leave the stock leads in place. 94
rutland
Aug 21, 2017 05:58 AM
Heisenberg
18
Mar 8, 2015 07:16 AM
suds1485
Honda Civic (2001 - 2005)
Feb 3, 2011 11:41 PM
97civic123
Audio / Security / Video
Aug 10, 2009 09:25 PM
DynastyRacer22
11
Jan 28, 2005 06:04 PM
