Bose RSX Sub? +/-?
Old Nov 16, 2006 | 05:20 AM
JohnnieChimpo's Avatar
Default Bose RSX Sub? +/-?
I am looking to add a little bass without taking up any room in my tiny car.
Does anyone here know what a RSX spare tire sub sounds like?
They're on ebay for $50.
Old Nov 16, 2006 | 06:48 AM
fcm's Avatar
fcm
Old Fart
Default Re: Bose RSX Sub? +/-? (JohnnieChimpo)
Are you adding it to a stock RSX Bose system? 94
Old Nov 16, 2006 | 12:30 PM
Default Re: Bose RSX Sub? +/-? (fcm)
No, I am not adding it to an RSX.
I just wanted a sub that fit in the spare tire well and I know Bose can make a lot of bass with small speakers, like in their Acoustamass system.
Old Nov 16, 2006 | 03:37 PM
B18C_EJ8's Avatar
If it's anything like other Bose speakers, it's not a standard 4 ohm driver... You'd need to find out what the impedence of the speaker is first, and amp it accordingly...
Old Nov 16, 2006 | 03:57 PM
fcm's Avatar
fcm
Old Fart
The problem you may run into is the impedance of the speaker, [sub] may be to low for a regular car amp, I would find out what the impedance of the sub is before you buy it.
Another alternative would be... http://cgi.ebay.com/Spare-Tire...wItem 94
Old Nov 16, 2006 | 04:46 PM
JSPECSIR's Avatar
if its the oem sub it has an amp built into it. feed it signal , ground, and 12v switched power and your good. it may also need a 12v continous wire, i cant remember, but alot of bose amps only use switched.
Old Nov 17, 2006 | 07:04 AM
fcm's Avatar
fcm
Old Fart
Default Re: Bose RSX Sub? +/-? (JSPECSIR)
Problem is, it comes with no harness, I wasn't sure if it had the amp built in although the one I linked does and it has the harness. 94
Old Nov 19, 2006 | 01:49 PM
incubus's Avatar
what car are you trying to put it in? they are barely audible to me in a RSX so if u are using it in a sealed trunk you might not hear it.
FYI the bose spare tire well subs are actually a Pioneer design, the driver inside may be a BOSE (or it may not I have never checked) but the enclosure is a Pioneer enclosure.
DJC9
Jul 18, 2017 03:33 PM
mr abstract
Audio / Security / Video
Sep 18, 2006 06:24 PM
strivin4dc5
Feb 2, 2005 01:39 PM
duRritztiNy
14
Sep 30, 2003 12:16 PM
