Rsx sub
Old Sep 27, 2003 | 11:09 AM
duRritztiNy's Avatar
Default Rsx sub
Has anyone tired to put an rsx sub into like a civic or something?
You think it will still give u a lil bump still?
Old Sep 27, 2003 | 06:07 PM
TurboBumblBee's Avatar
Default Re: Rsx sub (SouthSideRacing)
never tried it but it is something that is probably do able.. and i think it might sound ok for someone that doesnt want to load down there car.. its is only an 6 or 8" sub w/ a small bose amp..
Old Sep 27, 2003 | 07:14 PM
Default Re: Rsx sub (Hybrid95CivicEX)
yea i was planning to do that. Casue i want dont want alot of weight in the car, but the rsx sub will give me some bump and plus it doesnt weight that much. Anyone know wat kinda plugs are on the Rsx subs?
Old Sep 28, 2003 | 07:03 AM
PetroGuyX's Avatar
it's a bose sub, don't try it, that's all i have to say
Old Sep 28, 2003 | 07:50 AM
Default Re: (PetroGuyX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PetroGuyX &raquo;</TD></TR><TR><TD CLASS="quote">it's a bose sub, don't try it, that's all i have to say</TD></TR></TABLE>
have u tired it?
Old Sep 28, 2003 | 10:30 AM
PetroGuyX's Avatar
i've never tried it, i just don't see how it can work, i've worked on an RSX before, my friend has a type-s, but anyway, the bose amp isnt JUST for the sub, it's also for the 6 speakers, it doesn't have rca's and all that good stuff, it's a FACTORY amp, it uses speaker wires and it's a bitch to get out and if you take it out the speakers in the RSX don't work, you pretty much have to gut the whole system, i don't think you'd be able to do it, but i'd love to see it if you could, i personally would go with something that would last you a while, BOSE tends to suck *** and doesnt last
Old Sep 28, 2003 | 07:16 PM
HiRevn's Avatar
I don't think it will work. I knew this guy that had an old Maxima with a Bose system in it. When it blew a speaker, it had to be replaced with a Bose speaker. The system would not work with any other speakers. Like Petro said, you may have to bring over the whole system to make it work.
Old Sep 28, 2003 | 07:23 PM
Street_Kings's Avatar
actually, it will work. I did a custom 15" spare tire well sub install for a guy and one of the terms is i got to keep his sub. By saying it hits decently, though, is pushing it. If you can get one for free i say go for it...There are 4 wires on the input harness. Cut the harness off. One of the wires, you will notice, is bigger than the others. thats the power. black is ground, and the other two are the sound inputs. cut them, tap into your constant/ground, and your low level output on your amp, and you are good to go.
Old Sep 29, 2003 | 07:01 PM
jdkindle's Avatar
Default Re: (Street_Kings)
it will work as he said...........alot of S2K owners are doing it
you can get an adapter to make the job relatively easy
the enclosure has an amp in it that is seperate from the amp of the other speakers which is located under the passengers seat
I have an enclosure I will sell for $75 shipped if you want it
Old Sep 29, 2003 | 07:16 PM
jdkindle's Avatar
Default Re: (jdkindle)
heres a pic
Old Sep 29, 2003 | 11:16 PM
EGRhatch's Avatar
gotta be registered at that forum to see the pic...
Old Sep 30, 2003 | 04:39 AM
rjr162's Avatar
Default Re: (EGRhatch)
it's hardly worth it. Remember, the RSX is a hatch... you don't need much of a "sub" to hear it in a hatch. Anythign with a trunk, forget it, unless you can manage to fit it under a front seat.
Old Sep 30, 2003 | 10:42 AM
Default Re: (rjr162)
how much does an rsx sub weigh?
Old Sep 30, 2003 | 11:26 AM
jdkindle's Avatar
Default Re: (SouthSideRacing)
7lb 3 oz to be exact
that is the sub, the enclosure and the amp
Old Sep 30, 2003 | 12:16 PM
CRX7's Avatar
Currenlty working on putting one in my S2k, I'll let you guys know how it sounds when I'm done.
JohnnieChimpo
Audio / Security / Video
Nov 19, 2006 01:49 PM
strivin4dc5
Feb 2, 2005 01:39 PM
Al Bundy
Jan 10, 2003 10:38 PM
