BLOWING FUSES
Old Jul 27, 2004 | 06:38 PM
ChronicFrogs2004's Avatar
Default BLOWING FUSES
I have blown about 4 or 5 fuses now and I want to know why everytime that i turn the Vol. on my HU my amp fuse blows...
I have a CHEAP 1600Watt 2CH Pyramid AMP bridged to two 12'' subs... can it be because I have two subs bridged together? everyone I know says thats not it but they dont know what the problem is.
I have a cheap old 40X4 Panasonic HU
(that amp volume is only half way up)
Thank You For Your Help
CF04
Old Jul 27, 2004 | 08:03 PM
john666's Avatar
Default Re: BLOWING FUSES (ChronicFrogs2004)
what fuse is blowing out ? my friend used the small cheap glass fuses for the battery to amp, and whenever he would crack it up fast it would burn the fuse. he just had to turn it up slowly.
Old Jul 27, 2004 | 10:38 PM
Skitals's Avatar
I would make sure the ground for your amp is good.
Old Jul 27, 2004 | 10:45 PM
Default .............
Its not the fuse that is one the power wire it is a fuse that plugs into the amp it self ... it is a little plastic yellow thing with the number 20 on the back.
(the amp's book says to use an 20 fuse when replacing it)
CF04
Old Jul 27, 2004 | 10:48 PM
philly-O's Avatar
Default Re: (Skitals)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skitals &raquo;</TD></TR><TR><TD CLASS="quote">I would make sure the ground for your amp is good.</TD></TR></TABLE>
double
Old Jul 27, 2004 | 11:35 PM
Default Re: (peichie)
how do i check if the ground is good?...
where the ground is the paint is all off and it is bloted down... it is a short dis. from the amp also
CF04
Old Jul 28, 2004 | 07:15 AM
fcm's Avatar
fcm
Old Fart
Default Re: (ChronicFrogs2004)
Two things I would check.
1- is the amp stable at 2 OEMs when bridged? if you have two 4 oem speakers wired in parallel wired to a bridged amp that is not stable, it will get very hot and blow fuses
2- have the speakers been damaged, [voice coils] and are the shorting out at there xmax?
94
Old Jul 28, 2004 | 09:15 AM
chamillion's Avatar
Ohm load, and ground. One of them will be the culprit.
Old Jul 28, 2004 | 09:43 AM
spark plugs.
Guest
Posts: n/a
Default Re: BLOWING FUSES (chamillion)
ohm load, ground, or (because it's a pyramid) the amp could just be not good anymore. i've run into customers who's had the same thing. they come in with a pyramid or pyle amp and ground the amp by accident or something like that then it's **** after that.
Old Jul 28, 2004 | 03:05 PM
Default Re: BLOWING FUSES (spark plugs.)
RMS Power @ 4 Ohms 75Watts X2 |
RMS Power @ 2 Ohms 120Watts X2 |
Maximun Power Output 800Watts X2 |
Stereo Mode 2-4 Ohm |
Bridged Mode 4-8 Ohm |
^^Cant Handle two 4ohm subs hooked up bridged at the same time?(i dont know what wired in parallel means)
The Subs Are Brand New So I Dont Think They Are Damaged
Old Jul 28, 2004 | 05:56 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChronicFrogs2004 &raquo;</TD></TR><TR><TD CLASS="quote">RMS Power @ 4 Ohms 75Watts X2 |
</TD></TR></TABLE> Bridged Mode 4-8 Ohm, two 4 ohm speakers wired in parallel is a 2ohm load, your amp does not like that , you can run the amp in stereo and wire one ch. to each sub,or wire the speakers in series [8ohm load] and bridge the amp.
hope this helps.94
Old Jul 28, 2004 | 06:18 PM
Eric R's Avatar
Default Re: BLOWING FUSES (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Bridged Mode 4-8 Ohm, two 4 ohm speakers wired in parallel is a 2ohm load, your amp does not like that , you can run the amp in stereo and wire one ch. to each sub,or wire the speakers in series [8ohm load] and bridge the amp.
hope this helps.94</TD></TR></TABLE>
Agreed with that!
Just run the subs in stereo = Cooler cheap amp.
Old Jul 28, 2004 | 10:38 PM
Default Re: BLOWING FUSES (Eric's R)
How would I go about wireing the speakers in series ?..... How do I do it?
CF04
Old Jul 31, 2004 | 06:59 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChronicFrogs2004 &raquo;</TD></TR><TR><TD CLASS="quote">How would I go about wireing the speakers in series ?..... How do I do it?
CF04</TD></TR></TABLE> Each speaker has a pos. and a neg. term., run a wire from the pos. of one speaker to the neg. of the other speaker, that will leave you with one pos. and one neg., run them to your amp, bridge amp, it will "see" an 8OHM load,
output of amp will be about 75 watts, kind of low for two 12s, but worth a try.
hope this helps. 94
jiro
Honda Civic (2006 - 2015)
Feb 6, 2010 11:11 PM
Spazbaboon
Audio / Security / Video
Feb 26, 2007 03:36 PM
ilikemyaccord
Aug 13, 2004 04:36 PM
walkerrod
Jun 2, 2004 08:57 AM
pr0jektdc2
Feb 9, 2003 01:19 PM
