Blinking LED alarm indicator
Old Jan 3, 2003 | 09:34 AM
muskrat's Avatar
Default Blinking LED alarm indicator
How would I wire up a blinking LED to turn on when I shut off my ignition? I know they sell units that do this, but I'd rather save some cash and set it up myself, just don't know how to wire the thing. TIA
Old Jan 3, 2003 | 09:38 AM
RaceTilIDie's Avatar
Default Re: Blinking LED alarm indicator (muskrat)
Those things are so cheap, you would spend more buying all the parts and doing it yourself. I think we sold them for $5, so I'm sure you can find them cheaper online.
Old Jan 3, 2003 | 09:42 AM
muskrat's Avatar
Default Re: Blinking LED alarm indicator (RaceTilIDie)
Parts? I've got LEDs and wire, what else could there be? Maybe a relay? Just got to know what to wire it to.
Old Jan 3, 2003 | 09:57 AM
You will need resistor, capacitor, and oscillator. Those alone will be more than an entire flashing LED.
Old Jan 3, 2003 | 10:06 AM
muskrat's Avatar
You will need resistor, capacitor , and oscillator . Those alone will be more than an entire flashing LED.
Help me out here...
Resistor: would this be to lower the voltage so you wouldn't burn the LED? I've got a 12 volt LED
Capacitor: These store power, what would I need it for? I've got capacitors.
Oscillator: Help me out with this one.
Thanks.
Old Jan 3, 2003 | 10:23 AM
Here are some sites if you want to do it for fun or a challenge, but your just reinventing the wheel when the flashing LEDs are $2:
http://space.tin.it/scienza/fladelle/Page14.htm
http://discovercircuits.com/L/LED.htm
Old Jan 3, 2003 | 10:39 AM
muskrat's Avatar
Thanks but maybe I'm not making myself clear. I can easily wire a flashing LED into my car, and I could put it on a switch if I wanted, but I just want to wire it up so that when the ignition is turned off, it turns on. This should be pretty simple right? All in the wiring I would assume, but I don't know of something to wire it to that becomes hot when the ignition is switched off.
Old Jan 3, 2003 | 10:43 AM
Oh, yeah I misunderstood you sorry. In that case it's easy. Wire up the + to 12 volts constant and run the ground to the ignition wire( I always ran them to the ignition harness wire). That wire rests at ground and is powered whith key on. THat is the normal way to do it.
Old Jan 3, 2003 | 10:50 AM
muskrat's Avatar
So you're just switching the negative instead of the positive... gotcha.
Old Jan 3, 2003 | 10:52 AM
Sorry I misunderstood you at first.
Old Jan 3, 2003 | 10:56 AM
muskrat's Avatar
It's cool, thanks for the eventual help! haha
Old Jan 3, 2003 | 11:16 AM
o_Rage_o's Avatar
lol that was priceless
-Rage
chillerice
Audio / Security / Video
Apr 30, 2013 07:54 PM
JDMgunmetalCRX
Mar 18, 2009 11:27 AM
Dub C
Sep 13, 2008 11:49 AM
EnSAn
24
Aug 10, 2006 08:36 AM
SleekBlkPrelude
Mar 26, 2003 12:09 PM
