big three/starter cable question
Old Jun 2, 2008 | 05:00 AM
CoolRedXylophone's Avatar
Default big three/starter cable question
Im doing the big three upgrade on my 88 crx. Ive run a 4ga wire from the 170 amp HO alt to the underhood fuse box and I am going to run a 4ga wire to ground the batt and the engine. my positive battery terminal has two 4ga outputs and two 8 gauge. I need one of the 4 gauge outputs to go to the underhood fuse box and the other to go to the amp. Im only left with the two 8ga for the starter. should i just run two 8 ga wires to the starter or will one be fine? Also, will this set up work ok? thanks
Old Jun 2, 2008 | 05:39 AM
fcm's Avatar
fcm
Old Fart
Default Re: big three/starter cable question (CoolRedXylophone)
Run the 4ga from the alt. directly to the batt. then run an 8ga from the batt. to the fuse box, your cars electrical does not need a 4ga between the batt. and fuse box. 94
Old Jun 2, 2008 | 05:56 AM
Default Re: big three/starter cable question (fcm)
dumb question but just want to make sure, run the alt to the batts postive terminal correct?
Old Jun 2, 2008 | 06:52 AM
fcm's Avatar
fcm
Old Fart
That would be correct.
You should be able to fit the starter motors 6ga into the remaining 8ga hole. 94
DialedLife
Mar 31, 2019 12:07 PM
Mr.Death
Apr 7, 2010 06:19 AM
lilo_goki
Aug 22, 2008 03:46 PM
JDMBOOGERHATCH
14
Mar 12, 2005 06:35 PM
