better speaker in front or back
Old Feb 28, 2004 | 11:13 AM
slowacura's Avatar
Default better speaker in front or back
i bought two sets of speakers, one better than the other. should i put the better ones in the front or back. or does it even make a difference
Old Feb 28, 2004 | 11:16 AM
corona's Avatar
Default Re: better speaker in front or back (inteGSR)
when you go to a concert, do face away from the stage, or towards it?
front.
Old Feb 28, 2004 | 11:50 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Your main focus as far as sound stage should be the front speakers. Some high end car audio installs don't even use rear speakers. If they do, it's referred to simply as "rear fill". For this reason, separates should not be necessary for the back. A decent 2-way 6.5" speaker will do fine.
Old Feb 28, 2004 | 01:28 PM
RedTegLS's Avatar
I agree. Actually I think eually good speakers in the front and rear mess with the sound. You want better quality up front.
Old Feb 28, 2004 | 01:43 PM
slowacura's Avatar
Default Re: better speaker in front or back (RedTegLS)
thanks for the tips guys. i just finished installing them. but the better speakers were too deep to fit in the front so i just ended up sticking the better ones in the back and the smaller ones in the front. it was a pain trying to fit them through those holes
Old Feb 28, 2004 | 02:00 PM
corona's Avatar
they hit the door panel? or they couldn't fit in the plastic basket?
Old Feb 28, 2004 | 02:14 PM
kreamy's Avatar
i had custom 6.5 inch wood brackets made for my kaption component speakers in the front and i must say it was worth it....i get much better sound out of the two front speakers!
Old Feb 28, 2004 | 02:32 PM
mrwink's Avatar
Default Re: (kreamy)
you are going to have to modify the basket that fits in the front door panels. either that, or buy speakers that aren't as deep. my boston acoustics were too deep and i had to just modify the plastic basket to make them fit correctly. and like everyone (or most everyone) said, you want the better speakers up front. why have all the good sound in the back? you want it as close to you as possible. that's why i have an amp powering my front components, not my back. the back is just filller, like someone else said earlier.
Old Feb 28, 2004 | 02:35 PM
slowacura's Avatar
Default Re: (mrwink)
yeah i would've chopped up that plastic bracket but i didn't have a saw. i'll borrow one and modify it. sounds like it'll be worth it
Old Feb 28, 2004 | 05:49 PM
HiRevn's Avatar
Default Re: (inteGSR)
I ended up cutting off the end of the plastic basket when I installed Kappas in my car.
Old Feb 28, 2004 | 07:57 PM
rjr162's Avatar
Default Re: (HiRevn)
I Think the only speakers that fit in any Honda without cutting the back of those baskets off are el cheapo's (IE> profiles) or Pioneer 6.5s... make sense since pioneer makes most of the factory speakers anyhow.
Old Feb 29, 2004 | 03:44 PM
snoochtodanooch's Avatar
Default Re: (rjr162)
seriously if you just have wire cutter you can cut the basket. just take it out at the part where it has the air vents. i used a jig saw and just chopped the bastard up. You will definently notice a difference with the better speakers up front.
Old Feb 29, 2004 | 05:34 PM
bub838's Avatar
i dont use rear speakers. i just use my fronts and a sub. sounds great to me.
hieungu1155
Audio / Security / Video
15
Sep 21, 2009 08:10 PM
digdug18
Jun 11, 2006 07:15 PM
Kryptonite
Jan 13, 2004 04:31 PM
Hcivic88
Apr 28, 2002 06:53 AM
Frost94GSR
Feb 25, 2002 10:25 PM
