which is a better ohm to go with?
Old Mar 7, 2004 | 01:07 PM
1SIKCRX's Avatar
Default which is a better ohm to go with?
i'm buying 2 "new" 10" sub's off of my friend 1 is a rockford fosgate RFP3410 and the other on is a rockford fosgate RFD3810!!
now i've been looking online to see the specs of the 2 and what not. and the RFP3410 is an impedance-4 ohms. and the RFP3810 is an impedance-8 ohms.
which is a better ohm to go with? can i still run the 2 in a box off of the same amp?
i'm new to the audio part of the car sceen!
thanks
Old Mar 7, 2004 | 01:45 PM
rcurley55's Avatar
New User
Default Re: which is a better ohm to go with? (1SIKCRX)
you can not run those two in the same box or off of the same amplifier - well, you could but you don't want to - you need matching subs.
That sub you choose is entirely dependent upon your choice of amplifier...
Old Mar 7, 2004 | 03:19 PM
1SIKCRX's Avatar
Default Re: which is a better ohm to go with? (rcurley55)
thanks.
my amp is a 2-4 ohm. so i should go with the 4 ohm sub's then?
thanks
Old Mar 8, 2004 | 07:38 AM
Boxcar's Avatar
it depends on what the subs can take u are proble better off going with just one sub anyway in a CRX 2 subs is very much over kill
Old Mar 9, 2004 | 02:19 AM
Xsi's Avatar
Xsi
Yes, don't put different subs in the same car, you'll never get it to sound right. You should probably go with the 4, bridge your amp to run at 2 ohms. Check the power ratings first though.
Old Mar 9, 2004 | 06:01 PM
Smashback's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SIKCRX &raquo;</TD></TR><TR><TD CLASS="quote">thanks.
thanks</TD></TR></TABLE>
The lower the number (i.e. 2ohm) the more distortion. However, this also allows the amp to run more power to the speaker (less resistance). In a car, you typically can't hear the difference in distortion between an 8 and 4 ohm speaker, or even 2...all that road noise plus with a sub your brains are usually rattling to much to know the difference
So, if you want the loudest, get the lowest impedence your amp will handle. I run my Punch 300 at 2 ohms even though it's only rated down to 4.
Old Mar 11, 2004 | 04:51 AM
1SIKCRX's Avatar
Default Re: which is a better ohm to go with? (HatchbackComeback)
ok my amp is a 4 channel amp. when bridged it is at 4 ohm stable. so should i go with the 2 8 ohms subs and wire them paralle? or get the 2 4 ohms sub and wire them....???
thanks for the help
Old Mar 12, 2004 | 08:51 PM
Smashback's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SIKCRX &raquo;</TD></TR><TR><TD CLASS="quote">ok my amp is a 4 channel amp. when bridged it is at 4 ohm stable. so should i go with the 2 8 ohms subs and wire them paralle? or get the 2 4 ohms sub and wire them....???
thanks for the help</TD></TR></TABLE>
Go with the 2x 8ohms in parallel, which gives you 4 ohms. 2x 4 ohm subs in parallel = 2 ohms, and 2x4 ohms in series = 8 ohms.
Civic_07
Audio / Security / Video
Sep 18, 2008 07:10 PM
cd5-obsession
Apr 19, 2007 01:17 PM
vtec8804
Apr 19, 2007 11:58 AM
tegrunner
Jun 29, 2005 06:25 PM
Nader_D
Jan 23, 2003 09:50 PM
