which is better
Old Apr 18, 2007 | 07:34 PM
oilguzzler's Avatar
Default which is better
im looking at gettting a pair of subs, which would be better(assuming same price)? 2 PPI DCX 124's or 2 Kicker 06CVX12-2's? and what kinda watts should i need to puch these(like would a PPI D2000/1 be sufficient?) thanks
Old Apr 18, 2007 | 08:21 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: which is better (oilguzzler)
taking that you stock charging system is not going to be able to push a 2k amp I say stick to about 500-600rms. Both speakers are good that you listed.
Old Apr 18, 2007 | 08:23 PM
oilguzzler's Avatar
Default Re: which is better (wrx-killer-Sti eater)
i rebuilt/built up my alt so i can push it now. i dont know which ones i should choose...
Old Apr 18, 2007 | 08:54 PM
what is the output of it now? The choice is up to you. you picked two good line of speakers. Both perform great and are of good quality. Its going to be up to the install of the product and enclosure size and car to determine anything. No body is going to say this one wins hands down and is the top dog
Old Apr 18, 2007 | 08:55 PM
dad0c402's Avatar
Seems like your aiming high, both sound great. I'm more of a kicker person, lots of experience with them and it's been all great stuff. Kicker goes above and beyond, if you buy an amp from them and it's rated for so high of a rms, it comes with a birthcertificate that says what they tested it to be, and it's always higher then advertised. Of course there's lots of other things to consider then just the sub, enclosure, power source, amp, capacitor, everything plays some kind of a role.
btw, something like a single L7 built to hit hard impresses me, not something that just looks amazing but sounds loud w/ no umpt behind it.
Old Apr 19, 2007 | 07:48 PM
oilguzzler's Avatar
Default Re: which is better (dad0c402)
this is going in my teg with a vented enclosure. im not sure what to get... dual 2 ohm would be better then dual 4 ohm right? or what
Old Apr 20, 2007 | 09:34 AM
imadigitalgod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oilguzzler &raquo;</TD></TR><TR><TD CLASS="quote">this is going in my teg with a vented enclosure. im not sure what to get... dual 2 ohm would be better then dual 4 ohm right? or what</TD></TR></TABLE>
well one isnt better than the other, it just gives you different wiring options for different power outputs of an amp(or to match the subs wiring to a specific amp)
dual 2 ohm will give you the option of making it a 1 ohm or a 4 ohm speaker when wired in parallel or series, respectively.
a dual 4 ohm will give you the option of making it a 2 ohm or an 8 ohm when wired in parallel or series, respectively.
<U>This is if you are wanting to use 2 of the same type of sub:</U>
if you want to put a 1 ohm load on your amp, you will need the dual 4 ohm(running the voice coils in parallel and the subs in parallel)
if you want the to put a 2 ohm load on your amp, you will need the dual 2 ohm sub(run voice coils in series and subs in parallel)
if you want a 4 ohm load on your amp, you will need the dual 4 ohm sub(voice coils in series and subs in parallel)
Old Apr 24, 2007 | 08:20 PM
oilguzzler's Avatar
Default Re: which is better (imadigitalgod)
k so i bought the PPI d2000/1 and 2 PPI DCX 124. i should be able to wire it up 1 ohm and the amp should handle it right? its says its one ohm stable. anyone have experiance with this amp/situation?
Old Apr 25, 2007 | 09:39 PM
if those are the dual 4 ohm subs, you need to wire each voice coil to the amp.
One easy way to do this is to wire the first voice coil of each sub to the amp, then wire the negative of the 2nd voice coil to the negative of the first coil and the positive of the 2nd coil to the positive of the first coil on each sub.
Old Apr 30, 2007 | 08:34 PM
oilguzzler's Avatar
yea i know, thats what i did with my PCC 122's. but the first thing i did was in a hurry to get my system going and forgot to wire up the second voice coils...lets just say i was back to the dealer in a week with brand new blown subs lol
Old May 2, 2007 | 06:59 PM
awdSiR's Avatar
I haven't had any experience with the PPI's but my bro's running two COMP X 12's in his accord with a kicker ZX1500 mono block at 2 ohms, let me tell u what that thing hits hard!!! Kicker is a good brand i've never had or heard any complains about there stuff..Good luck with ur new set-up
KooK
Audio / Security / Video
Dec 12, 2003 05:50 PM
Nader_D
Feb 10, 2003 10:53 AM
Aaron M
Sep 18, 2002 11:32 PM
C1DC2
Sep 11, 2002 06:03 PM
