Besides dynomat......
Old Nov 11, 2003 | 09:13 PM
greebler's Avatar
Default Besides dynomat......
So I am not looking for some major sound deading material, just somthing to line my trunk floor to quite down suspension and exhaust. May do the doors wile im at it.
My question is, is there anything that is cheaper than dynomat that <U>dosn't weigh to much</U> ?? Any sites to check out, with brand names would help me out.
Thanks Guys!
Old Nov 11, 2003 | 09:49 PM
rcurley55's Avatar
New User
there's a search function...use it!!
Seriously, this topic has been beat to death around here....the horse is not only dead, it's now paste!
search the archives for dynamat and you will find all the info you need.
Old Nov 11, 2003 | 10:04 PM
hybridzOr's Avatar
Default Re: (rcurley55)
id like to say.........cotton *****
Old Nov 12, 2003 | 08:43 AM
RiceRacist's Avatar
Default Re: (HybridRacer)
expanding foam works great for sound deadening. Costs about 6 bucks per canister and can cover quite a bit. I did my doors and hatch in my gutted rex and it cut the noise down a lot and saved a **** load of money
Old Nov 12, 2003 | 08:48 AM
GroundZer0 336's Avatar
Default Re: (RiceRacist)
i.m. me back kevin.
look for cascade spray dampening. it works and doesnt weigh much, its kinda like rubberized undercoating i guess.
Old Nov 14, 2003 | 01:19 PM
PupaScoopa's Avatar
Default Re: (lowlife4life)
Roxul Safe and Sound is a residential/commercial sound deadening product that is installed in walls. It works great when stuffed very firmly between body/trim panels in your car. You can find it at some hardware stores or specialty insulation places. Keep it dry as it will soak up water and hold it, possibly causing rust.
Other than that, I doubt you'll beat Dynamat's (Extreme) sound deadening properties by weight.
Old Nov 16, 2003 | 01:37 AM
The Bagel's Avatar
Default Re: Besides dynomat...... (greebler)
Stinger makes a sound deadener called road kill, much like dynomat but lighter. I had it in my last car, worked well, no more "body in the trunk" noises...pricey though.
Old Nov 16, 2003 | 09:09 AM
EBP_SI's Avatar
Default Re: (PupaScoopa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PupaScoopa &raquo;</TD></TR><TR><TD CLASS="quote">Roxul Safe and Sound is a residential/commercial sound deadening product that is installed in walls. It works great when stuffed very firmly between body/trim panels in your car. You can find it at some hardware stores or specialty insulation places. Keep it dry as it will soak up water and hold it, possibly causing rust.
I thought about doing this too and i wondered about the moisture part of it. I'm thinking about putting it in a plastic bag or a big contractors garbage bag. you think that would work?
Old Nov 17, 2003 | 10:52 PM
NOOTRON20's Avatar
spray on undercoating like the fenderwalls have.
got some a while back @ McCoys for bout $7.00 a can
Austin_tacious
10
May 31, 2012 05:57 PM
badbu68
Aug 21, 2010 08:21 PM
jdwebmaster
Audio / Security / Video
12
Nov 4, 2003 12:16 PM
Brian*
Honda Motorcycles
12
Mar 4, 2003 07:47 PM
bemathew
Aug 26, 2001 12:45 AM
