battery issues
Old Jan 21, 2003 | 03:32 PM
ViZ's Avatar
ViZ
Default battery issues
Ok i just got my car from the body shop. they left the lights on one night i guess and the battery died.. then after tons of start and move start and move for a few weeks. so now it needs to jump and start since i havent let it run for more then 45 minutes at the very most.. so i decided to charge it with an old charger of ours... its real basic 6 or 12 volt and it has a meter on the front saying how many volts its using
now after about a minute it shuts off then 2 or 3 seconds it pops back on..
i can smell sulfer a little and i can hear a very mild bubbling and from chargin our forklifts at work im guessing this is normal
i have had this battery for a long time so it might need replaced but what causes it to keep turning off.
* i took it out of the car so i dont screw anything up
Old Jan 21, 2003 | 08:37 PM
nsxxtreme's Avatar
Default Re: battery issues (ViZ)
Did you hook it up correct? + to + -to -
Usually what will make a charger shut off is an overload.
Old Jan 22, 2003 | 06:53 PM
ViZ's Avatar
ViZ
Default Re: battery issues (nsxxtreme)
yes
Old Jan 22, 2003 | 07:45 PM
philly-O's Avatar
sounds like your battery is shot. you loose alot of capacity after deep cycling a battery.
specbb6
Honda Civic (2006 - 2015)
Jun 24, 2012 03:07 PM
tlsole
Jan 14, 2010 07:35 AM
Junkyard Dogg
May 7, 2006 05:34 PM
speedracer33
May 2, 2005 08:57 AM
ViZ
Jan 22, 2003 08:56 AM
