bass problem
Old Jul 25, 2005 | 02:00 AM
Mattyg2's Avatar
Default bass problem
ok i have a amp that does 200 watts rms and i have 4 guage wiring
my sub is a boss 12 inch dunno the specs
4 pioneer 4 way 6.5 speakers that do 50 watts rms each
pioneer hu
ok when i stop when i have my lights on or air on my bass goes out for a few seconds. what does this mean? i made my battery ground with 4 guage and made a new shorter spot for it with gold plated terminals. could it be my alternator grounds? or is it that my battery is very weak
Old Jul 25, 2005 | 06:21 AM
1G_DX_to_2G_Si's Avatar
sounds like you're getting a voltage drop, do the lights dim when you hit the brakes? if they do put a meter on the battery while the car is running, it should read ~14.4 volts. if its a lot lower than that check and charge the battery and if the problem persists, check the alternator. other than that check the wiring on the amp, especially the grounds.
Old Jul 25, 2005 | 09:47 AM
fcm's Avatar
fcm
Old Fart
Default Re: bass problem (Mattyg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mattyg2 &raquo;</TD></TR><TR><TD CLASS="quote">ok i have a amp that does 200 watts rms and i have 4 guage wiring
pioneer hu
ok when i stop when i have my lights on or air on my bass goes out for a few seconds. what does this mean? i made my battery ground with 4 guage and made a new shorter spot for it with gold plated terminals. could it be my alternator grounds? or is it that my battery is very weak</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1G_DX_to_2G_Si &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you're getting a voltage drop, do the lights dim when you hit the brakes? if they do put a meter on the battery while the car is running, it should read ~14.4 volts. if its a lot lower than that check and charge the battery and if the problem persists, check the alternator. other than that check the wiring on the amp, especially the grounds.</TD></TR></TABLE> Ditto that.
Or take the car to a batt. shop and get them to do a load/grav. check on the elec./charging system, it only takes a min. and most shops, [if not all] will do it for free, it will tell you what the volt and amp output of the alt. is, what condition the batt. is in and how much power is being drawn when things are on 94
Old Jul 25, 2005 | 12:36 PM
Mattyg2's Avatar
aight ill go try that
Old Jul 25, 2005 | 06:56 PM
Default Re: bass problem (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">
Ditto that.
see? not all n00bs are evil!
Old Jul 25, 2005 | 07:11 PM
Phat_Jax's Avatar
Default Re: bass problem (1G_DX_to_2G_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1G_DX_to_2G_Si &raquo;</TD></TR><TR><TD CLASS="quote">see? not all n00bs are evil! </TD></TR></TABLE>
no...just most.
Old Jul 26, 2005 | 06:01 AM
lol
Old Jul 26, 2005 | 07:40 AM
PupaScoopa's Avatar
Default Re: (1G_DX_to_2G_Si)
Hey, don't forget to check your grounds. I saw an issue like this and ever since I've doubled up on battery grounds and made very secure ground blocks for the amps.
Old Jul 26, 2005 | 11:07 AM
Mattyg2's Avatar
would making a new alternator ground benefit me?
Old Jul 27, 2005 | 08:15 AM
fcm's Avatar
fcm
Old Fart
Default Re: (Mattyg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mattyg2 &raquo;</TD></TR><TR><TD CLASS="quote">would making a new alternator ground benefit me?</TD></TR></TABLE>Upgrading grounds can never hurt, in most cases will definitely help 94
nyzd79
Mar 14, 2008 09:20 AM
vargas
Audio / Security / Video
Nov 29, 2007 05:58 PM
kyorishin
Jul 6, 2006 10:58 PM
redteg1
Apr 8, 2002 02:43 PM
lexusleo
Dec 11, 2001 08:34 AM
