EXTRA BATTERY ??
Old Nov 27, 2007 | 05:03 PM
vargas's Avatar
Default EXTRA BATTERY ??
umm.. so i need another battery to power my two tens cuz it will work for like twenty seconds then it dies out . anyone have experiences with this. cuz im pretty lost rite now. i know its not the amp or the wiring .
Old Nov 27, 2007 | 05:28 PM
bigluelok's Avatar
Default Re: EXTRA BATTERY ?? (vargas)
why dont you get a better alternator and a copasitor my homy has a 15 in his da with out a capasitor or extra battery no problem with it wat so ever
Old Nov 27, 2007 | 06:06 PM
fcm's Avatar
fcm
Old Fart
Unless your batt. is bad you have some other problem, possibly a short or low impedance, low current because of poor connections.
If you have an AGU fuse, [big glass type] on the amps power lead, replace it, even if it looks good.
Need more info...
1- MM&Y of car..
2- Make and model of amp
3- What is the amp running?
4- Make and model of speaker(s) amp is running
5- Where is amp mounted, and how/to what?
6- Where is amp grounded, and how/to what?
7- How long is the amps ground lead?
8- What gauge is the amps power and ground leads?
9- Is the amps power lead connected directly to the batt. pos.(+) post?
10- When the amp cuts out, how do you get it to work again?
Please answer all the above, it will make it easier to figure out what your problem is. 94
Old Nov 28, 2007 | 04:05 AM
White Smoke's Avatar
i my honda
Global Mod
It does not sound like your problem has anything to do with your battery.
You would only need a second battery if you were having troubles with the battery dying when the car is turned off. Otherwise it's the alternator providing all the current. If you do end up adding a second battery you will need to get an isolator.
More info on extra battery's.
http://www.crutchfield.com/S-X....html
http://www.caraudiohelp.com/ca...s.htm
Old Nov 29, 2007 | 05:58 PM
baller status's Avatar
Tens of thoasands of people are running two tens or even two twelves with a single car battery and no problems.
chillerice
Audio / Security / Video
12
Feb 9, 2013 07:32 PM
fryman
Jun 11, 2008 05:41 AM
carloselpavo
11
Sep 26, 2007 06:46 PM
gwsexton425
May 22, 2005 02:53 PM
shorty0o29
Apr 15, 2003 06:27 AM
