ATTN: Evil Teken
Old Oct 2, 2002 | 01:57 PM
  #26
nsxxtreme's Avatar
Default Re: ATTN: Evil Teken (integra-modder)
Also, I hooked up the gray wire to a +12V when the car was on and the heater still did not turn on.
WTF is up with it?
Did you leave the fan turned on?
Old Oct 2, 2002 | 04:15 PM
  #27
integra-modder's Avatar
Default Re: ATTN: Evil Teken (nsxxtreme)
when i hooked up the wire? yes
edit: could it possibly be a fuse?
[Modified by integra-modder, 8:15 PM 10/2/2002]
Old Oct 2, 2002 | 05:08 PM
  #28
nsxxtreme's Avatar
You have to leave the heater controls where you want them when you turn the car off. So if your heater works when you turn the car on it will work when you turn the car off and remote start it. If it doesn't work at all with the car on then you probably screwed something up, check the fuse. Maybe this is what screwed your intellistart up.
Does your heater work with the key on?
It would be pointless to connect the gray wire to +12V when the car is on, this part is already getting 12V from the key switch.
As I said before I suggest you get someone to help you that knows how to install and can see your installation. Diagnosing over the internet is useless.
[Modified by nsxxtreme, 6:16 PM 10/2/2002]
Old Oct 2, 2002 | 08:34 PM
  #29
you know of anyone local to baltimore area?
the heater doesnt work at all...
Old Oct 3, 2002 | 12:48 PM
  #30
anything?
Old Oct 3, 2002 | 02:03 PM
  #31
nsxxtreme's Avatar
I don't know anyone in Baltimore.
Anyone else know anyone that can help him out?
Old Oct 4, 2002 | 02:29 AM
  #32
I was talking to the guy I bought the system from, and he suggested that I disconnect the brown wires (parking lights) and see if that does anything, he says they might be sending current back into the AG4 when you arm and the lights flash. So ill try that today.
Old Oct 6, 2002 | 07:11 AM
  #33
got the lights working, and the whole alarm is functioning except for the remote start....
when I send the channel 11 signal, I can hear the relays click and see the lights flash, however when i turn off the key, the car shuts down.
I hear about 3 or 4 clicks total, and if I turn the key to off before the 3rd or 4th click, the car runs until the last click comes and then shuts down.
Anyone know how evil teken could have not seen this post?
cmatt
May 1, 2018 02:32 PM
schwinn
Audio / Security / Video
Jun 13, 2002 06:56 PM
SoCal ITR
Apr 11, 2002 12:41 PM
