Anyone running multi battery setups??
Old Apr 26, 2004 | 12:56 PM
tweekerz's Avatar
Default Anyone running multi battery setups??
I will be running over 3000 watts and am looking into a multi-battery setup. Anyone have experience doing this and whats your electrical setup??
Old Apr 26, 2004 | 04:27 PM
sopiwnykg's Avatar
Default Re: Anyone running multi battery setups?? (GoodTimes)
Just get a battery isolator that will be rated high enough for you application and follow the instructions to hook it up. You may want to look at get a high output alternator and a cap before doing this though.
Old Apr 27, 2004 | 05:02 AM
tweekerz's Avatar
Default Re: Anyone running multi battery setups?? (sopiwnykg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sopiwnykg &raquo;</TD></TR><TR><TD CLASS="quote">Just get a battery isolator that will be rated high enough for you application and follow the instructions to hook it up. You may want to look at get a high output alternator and a cap before doing this though.</TD></TR></TABLE>
Yeah I am looking at a 200amp alternator. My concerns are what kind of battery do I need. Which battery would work in front and in the back, yellow top in front and red top in back?
Old Apr 27, 2004 | 06:49 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Actually it would be the opposite, you need a red top in front and yellows in back. Also, if you don't bump alot with the engine off the extra batts aren't going to help you. That is the only thing they help you with.
Old Apr 27, 2004 | 07:17 AM
tweekerz's Avatar
Default Re: Anyone running multi battery setups?? (rochesterricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer &raquo;</TD></TR><TR><TD CLASS="quote">Actually it would be the opposite, you need a red top in front and yellows in back. Also, if you don't bump alot with the engine off the extra batts aren't going to help you. That is the only thing they help you with.</TD></TR></TABLE>
What are the differences between the two batteries? And if I dont bump with the car off than only a red top in the front?
Old Apr 27, 2004 | 11:43 AM
ShaunRR's Avatar
HT White Ops
Community Builder
The reds are regular cycle and the yellows are deep cycle. A buddy of mine had a deep cycle up front and could never jump start it. If he ever left his lights on, he had to stick it on a charger. If you don't play with the key off, then you just need a red top up front. Remember the alternator generates power, all batteries do is store power. If you want to support more power, you need to generate more power.
Old Apr 27, 2004 | 12:22 PM
tweekerz's Avatar
For some reason I thought you have to run with a yellowtop up front, but looks like you can run either or.
htsang07
Lighting
Jul 15, 2008 10:07 AM
H22CD7
Audio / Security / Video
16
Jan 16, 2007 08:17 AM
idewson
Aug 31, 2006 11:45 AM
CRXDrew
May 11, 2005 01:24 AM
Boxcar
16
May 1, 2005 12:54 AM
