Amp turning off
Old Dec 3, 2004 | 10:26 AM
xoutlawz00x's Avatar
Default Amp turning off
what wires needed to be connected for the amp to stay on..
when i hook up the remote power and group and rca cable it turns on. then after like 20 secs the amp turns off. then when i move around the rca cable it turns back on..
can it be a bad rca wire shuttin the amp off
Old Dec 3, 2004 | 12:38 PM
Nyceguy17's Avatar
Default Re: Amp turning off (xoutlawz00x)
Are your RCA's grounding out against anything? Each other? Thats what it sounds like. Check out your ground as well. And make sure the Remote wire has 12v and not less than 10.
Old Dec 3, 2004 | 01:02 PM
Default Re: Amp turning off (Nyceguy17)
okay ill check tommroow
Old Dec 3, 2004 | 02:14 PM
AllMotoRex's Avatar
i was having the same problem, i hooked up 2 sets of rca's , but as soon as i hooked up hte second set it'd go into protection. so i just hooked up one set. POS>
its an earthquake amp. old school.
Old Dec 6, 2004 | 03:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nyceguy17 &raquo;</TD></TR><TR><TD CLASS="quote">Are your RCA's grounding out against anything? Each other? Thats what it sounds like. Check out your ground as well. And make sure the Remote wire has 12v and not less than 10.</TD></TR></TABLE>
yes ive checked it all.. and it still has that problem when i wiggle the wires up and down it comes on for like 15secs then turns off or if i bang it it turns on. and when it turns on when i take out the rca wires it stays on..
help i need my bass
Old Dec 6, 2004 | 05:17 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xoutlawz00x &raquo;</TD></TR><TR><TD CLASS="quote">
help i need my bass</TD></TR></TABLE>You have a "cold solder joint" on the PC board, its probably on the trigger wire, its just when you move the RCAs it moves the board. 94
Old Dec 6, 2004 | 05:50 PM
Default Re: Amp turning off (fcm)
how do i fix that
Old Dec 6, 2004 | 07:10 PM
help
Old Dec 15, 2004 | 10:28 AM
need help
Old Dec 15, 2004 | 01:10 PM
it turns off an on if i push terminals down i think it shorting out. but i don't knwo what to check
Old Dec 15, 2004 | 01:21 PM
willahlborn's Avatar
your wires are faulty OR as you've already been told you have a cold solder joint. wires are easy to fix but if it's the cold solder joint, you have to disassemble the amp and re-solder whatever joint is faulty. Usually not worth it.
Old Dec 15, 2004 | 01:24 PM
Default Re: Amp turning off (willahlborn)
i tried two different rca wires. still same **** i opened it up and couldn't find anything
froogle29
Audio / Security / Video
Oct 29, 2009 07:44 PM
accord64
Oct 3, 2007 08:19 PM
shabasoft
Aug 31, 2004 08:20 AM
iluvdrt
Oct 2, 2003 09:13 PM
SeaBass
May 16, 2003 08:26 PM
