amp cuts out
Old Oct 1, 2003 | 08:10 PM
iluvdrt's Avatar
Default amp cuts out
ok i have an eclipse head unit and a clairion 5 band eq running to 3 amps. two of my amps work great but the sub amp keeps cutting off when i turn the sound up to bump. its just a temp, but ill have to keep it for a while. any way i think its an Aura amp and i have it bridged at about 1/2 gain(it is brigeable). any ideas, oh i also have a 1/2 fared cap mated to it.
Old Oct 1, 2003 | 08:27 PM
acuradriva's Avatar
Default Re: amp cuts out (iluvdrt)
check the ground wire.
Old Oct 1, 2003 | 09:50 PM
blackhatchy's Avatar
Default Re: amp cuts out (acuradriva)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuradriva &raquo;</TD></TR><TR><TD CLASS="quote">check the ground wire.</TD></TR></TABLE>
and remote wire
Old Oct 1, 2003 | 10:35 PM
ATF Kuk's Avatar
check to see wut ohms ur sub is and wut ohm ur amp is stable at. wut subs do u have? wuts the rating on the amp?
Old Oct 2, 2003 | 01:36 PM
acuradriva's Avatar
Default Re: amp cuts out (blackhatchy)
positve wire too does the power light go out does a protection light come on?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhatchy &raquo;</TD></TR><TR><TD CLASS="quote">
and remote wire </TD></TR></TABLE>
Old Oct 2, 2003 | 03:18 PM
iluvdrt's Avatar
the protection light comes on. right now as far as subs go i have a junk *** sony xploder(i blew the punch xlt i had)so im not sur what that means. the other i had hooked up burned up(but it was a explode also so i just figured it was time to go as they are junk as well). but like i said it works fine until i get over like 1/3 volume.
Old Oct 2, 2003 | 06:07 PM
acuradriva's Avatar
try disconnecting the sub and see if it still does it.
Old Oct 2, 2003 | 06:38 PM
iluvdrt's Avatar
what would the sub have to with it? the ohms maybe or loose grounding wire? ill give it a shot.
Old Oct 2, 2003 | 08:43 PM
acuradriva's Avatar
Default Re: (iluvdrt)
yea if the impedence is to low it will send it into protection. chack and make sure everyhing is tight. expecailly the ground wire.
Old Oct 2, 2003 | 09:13 PM
rjr162's Avatar
Default Re: (acuradriva)
ah!!
what model is it? It is the Mono amp that's "able to run 3 subs"? If it's like 2 model years old, the amp i bet is shot. We had nearly every one of those we sold come back with that exact problem, and the funny thing is the ppl were only running 2 subs (2 ohm load) and not even the 3 it's suppose to be able to handle (what... 1.66666 ohms, correct?)
ws350z
Audio / Security / Video
Sep 26, 2008 09:35 PM
lsracer27
Jun 14, 2006 01:42 AM
B18Sleeper
13
Oct 2, 2005 11:35 AM
xoutlawz00x
11
Dec 15, 2004 01:24 PM
phreakmang
Mar 11, 2004 07:32 PM
