hooking up the sub/amp
Old May 15, 2003 | 03:58 PM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
Default hooking up the sub/amp
I had my subwoofer professionally installed about 18months ago. Last month, I had a B16A dropped in my '91 hatch, so the subwoofer wire was cut in the process.
Now, I extended the wire and hooked it up to the battery, but the amp/sub doesn't come on. Any ideas as to the problem? I have an all Sony system (got a $75 rebate), so Sony amp/sub/deck.
Thanks,
JF
Old May 15, 2003 | 05:33 PM
vteg's Avatar
New User
Default Re: hooking up the sub/amp (SeaBass)
Check your ground and remote lead. Hook up a DMM or test light between the positive and ground at the amp. If it has voltage I would check out the remote lead coming from the back of the headunit.
Old May 16, 2003 | 03:24 PM
ATF Kuk's Avatar
Default Re: hooking up the sub/amp (vteg)
also check fuses(if u got them)
Old May 16, 2003 | 08:26 PM
tomee's Avatar
make sure ur remote wire is not cut... as thats what turns on ur amp when ur head unit turns on..
also as said check ur grounds
froogle29
Audio / Security / Video
Oct 29, 2009 07:44 PM
jsteadman
Jul 8, 2009 08:04 AM
notguilty411
15
Apr 5, 2005 01:56 PM
Arsenal
Mar 9, 2004 07:06 PM
beef3000
May 28, 2003 05:18 PM
