which amp is suggested?
i have (1) 12" JL w6 and was wondering what is a good amp to go with it, right now i am using a 2 ch mtx amp, i bridged it with the sub wired in parallel and it sometimes doesnt work. im guessing b.c the amp isn't supposed to go lower then 4ohms bridged? is this correct? thanks
A safe bet would to be to go with any Fosgate (600w) but buy used and save yourself the money. Amps ususally have a decent life expectency.
what about memphis and JL? mono blocks? when an amp's spec says for instance, 300watts rms @ 4 ohms, can it be a little higher or lower ohms?
when bridged for 300 watts at 4 ohms, can i run at 3ohms? since the jl w6 is D6, so that means i cant get 4 ohms, so is it ok for me to run it at 3ohms when its supposed to be 4?
PPI = VERY reputable car audio manufacturer (known for their amps)
JL only does 500w @ 4 ohms for $350. For that amount of money, you can get a quality amp with more power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">PPI = VERY reputable car audio manufacturer (known for their amps)
JL only does 500w @ 4 ohms for $350. For that amount of money, you can get a quality amp with more power.</TD></TR></TABLE>
My arc does 900 watts @ 4 ohms bridged. It is about the same price per watt probably.
I recommend a jl amp because of those crazy impedances and 6 ohm coils.
skingfreak
Audio / Security / Video
Jun 26, 2006 06:58 PM
ctownintegra
Oct 29, 2004 07:57 PM
brickonwheels
Feb 1, 2004 09:44 AM
