amp question
Old Dec 25, 2004 | 10:31 PM
b18c1995's Avatar
Default amp question
Can i run all 4 of my speakers (without a sub) on a 2 channel amp? Im a noob when it comes to audio stuff. Im looking at a 300w blaupunkt 2 channel amp to power my alpine type R's (components in the front and coax in the rear). The power ratings for the speakers are 50W rms and 40W rms, respectively. Will that amp be enough to power all 4 speakers?
Old Dec 26, 2004 | 08:39 PM
Mazzazx51's Avatar
Default Re: amp question (b18c1995)
....Well you could...but it wouldn't be all that great.
If you put the left speakers on one channel and the right on the other the amp would be seeing 8ohms, effectively halving the power output. Yes you could wire them to see 2ohms but the amp is probably not rated for that and the speakers wouldn't like it either...But thats another story. Also you wouldnt have any fader control.
If I was you Id run the Alpines on the Blaupunkt (They love power, got mine running on 122WRMS), and run the rears off the HU, after all they're only there for fill.
Or you could get a good 4channel, run the alpines of 2 channels and later on bridge the other 2 and run a sub.
Old Dec 26, 2004 | 09:34 PM
ATF Kuk's Avatar
Default Re: amp question (Mazzazx51)
what do you mean amp not rated for 2 ohms? almost all stereo amplifiers are 2 ohm stable. when bridged is when you have a problem.
Old Dec 27, 2004 | 07:20 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1995 &raquo;</TD></TR><TR><TD CLASS="quote">Can i run all 4 of my speakers (without a sub) on a 2 channel amp? Im a noob when it comes to audio stuff. Im looking at a 300w blaupunkt 2 channel amp to power my alpine type R's (components in the front and coax in the rear). The power ratings for the speakers are 50W rms and 40W rms, respectively. Will that amp be enough to power all 4 speakers?</TD></TR></TABLE> Use the amp to run the front speakers, run the rears off the Hu, [for rear fill] if you run all 4 off the amp you will have a very crappy image, you would have to attenuate the rears somehow to move the image forward, if you use the amp on the fronts only and power the rears off the Hu, not only will it move the image forward,it will also give you more dynamic headroom for the fronts, where you need it, and a little power is all you need for the rear speakers, I would also not use tweets in the rear 94
m.glisson003
Audio / Security / Video
18
Aug 15, 2011 06:17 PM
GetawayInMoscow
Apr 13, 2009 02:41 PM
professorman
Jan 25, 2008 08:02 PM
ilikemyaccord
May 5, 2003 08:29 AM
Calavera
17
Jun 24, 2002 10:30 AM
