amp install (sort of...)
Old Feb 25, 2005 | 09:15 PM
cyco's Avatar
Default amp install (sort of...)
where else can you hook up a REM wire to instead of the blue/white ANT wire? for some reason, my back-up radio isn't sending a signal out so i was wonderin if anyone knew what else you could hook that wire up to without it killing the battery or anything like that. i got a 96 lude in case you need to know. thanks for the help
Old Feb 26, 2005 | 06:37 AM
hometheaterman's Avatar
Default Re: amp install (cyco)
Any switched power source.
Old Feb 26, 2005 | 09:03 AM
cyco's Avatar
Default Re: amp install (hometheaterman)
for example, can i hook it up to the vcc for the radio? or should i connect it somewhere else like the cig lighter or somethin?
Old Feb 28, 2005 | 08:12 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cyco &raquo;</TD></TR><TR><TD CLASS="quote">where else can you hook up a REM wire to instead of the blue/white ANT wire? for some reason, my back-up radio isn't sending a signal out so i was wonderin if anyone knew what else you could hook that wire up to without it killing the battery or anything like that. i got a 96 lude in case you need to know. thanks for the help</TD></TR></TABLE> Your Honda has both an acc. and a 2nd ign. freepin on the fusebox, use one of them.
Old Feb 28, 2005 | 09:21 PM
em1 Ziggy's Avatar
Default Re: amp install (fcm)
i had the same problem!!! soo i hooked it on on the fuse on the bottom of the dash.. my amp turned on.. but my head unit just didn't turn on.. now i think my head units broken!!
Old Mar 2, 2005 | 06:12 AM
fcm's Avatar
fcm
Old Fart
Default Re: amp install (eK Ziggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK Ziggy &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem!!! soo i hooked it on on the fuse on the bottom of the dash.. my amp turned on.. but my head unit just didn't turn on.. now i think my head units broken!!</TD></TR></TABLE> Or one of the fuses for the HU is blown, check the acc. one in the incar fusebox, and the 7.5A constant power in engine bay fusebox PS.... there will also be a fuse on the back of the HU or on the yellow constant power wire for the HU. 94
Jordan8742
Audio / Security / Video
Mar 25, 2015 09:19 AM
bopbop93030
13
May 5, 2009 11:08 AM
D17alltheway
May 2, 2008 01:06 PM
nasports
Feb 14, 2008 04:09 PM
PearlWhiteAccord
Jun 18, 2002 05:17 AM
