Amp has power but sub doesnt
Old Jan 4, 2010 | 05:28 PM
Mr.Meowsome's Avatar
Default Amp has power but sub doesnt
Car: 2000 Civic Si
Head unit: Alpine CDE-102
Amp: MTX thunder 4122
Sub: 10" Kenwood
Problem: Everything seems to be hooked up correctly as far as I know. I've never really done this before but it seems pretty straight forward and I can only think that it has something to do with the headunit. Anyway, I have a 0 gauge wire from the battery to a fuse then to the amp. Right now I have it grounded with a 0 gauge as well only cause thats what I had in front of me at the moment. Then the sub is hooked to a (+) on the right channel and (-) on the left channel. The RCA cables run from the sub-out on the headunit to the input on the amp. I went through the menu on the HU and turned the subwoofer option on as well. This all seems correct to me but I can only think that maybe I dont know my HU that well and I'm missing something else that has to be changed in the menu. I read the manual and it told me what I already know so I'm pretty stumped
Old Jan 4, 2010 | 07:40 PM
jorrego89's Avatar
New User
Default Re: Amp has power but sub doesnt
does the amp have a good ground? also check the rca, make sure their not cut. make sure all the connections inside the box are good.
Old Jan 4, 2010 | 07:57 PM
I pulled the sub out to check the connection and it was all good and the RCA cable is only 2 days old
Old Jan 4, 2010 | 08:17 PM
fcm's Avatar
fcm
Old Fart
Disconnect the subs speaker wire from the amp, touch the pos.(+) and neg.(-) speaker leads to the pos.(+) and neg.(-) of a batt., [9V works best but any batt. will work, AAA, AA, C, D and so on] the sub should "pop", if not, recheck the wiring, do the same test at the subs speaker terminal.
If sub "pops" sub and wiring is good, [you have continuity] problem is either amp, HU or wiring.
Reconnect the sub to amp, unplug the RCAs at the HU, lick a finger and touch one of the RCA center pin, [signal] and outside barrel, [signal return] at the same time, sub should "hum" if not, check RCAs and/or amp, if it does hum, try plugging RCAs into a front or rear output instead of the sub output and see what happens. 94
Old Jan 5, 2010 | 05:18 AM
punkdown's Avatar
You have the remote wire hooked up, right?
Old Jan 5, 2010 | 09:15 AM
I was looking at that and didn't know what that was for. I read somewhere else it has to be hooked up to the HU? Again I'm not familiar with this stuff
Old Jan 5, 2010 | 09:38 AM
So now that I know, it should be hooked up to a power source. Would the cigarette lighter be good since its only powered when the key is to the ON position?
Old Jan 5, 2010 | 12:08 PM
I ran a wire to the blue/white wire on the HU which is indicated as the remote wire and got nothing.
fcm, I haven't tried what you told me yet since I was missing an important wire and figured it was an easy fix. I'll try and narrow it down with what you told me and report back. I have a feeling that its the amp. The red light comes on but for some reason I think a connection isn't being made inside of it.
I also tried another amp but the light on the amp doesn't even come on and the fuse is fine, so that's another issue to deal with
Old Jan 5, 2010 | 12:20 PM
mhart's Avatar
hook it up to the power antenna wire.
Old Jan 5, 2010 | 01:20 PM
Tried that. No dice
Old Jan 7, 2010 | 01:41 PM
Tested the connections and all were good. I tried opening the amp but I dont have the right size torx bit
Old Jan 7, 2010 | 02:26 PM
Maluko's Avatar
your amp might not be working..or the sub.. one of the two
Old Jan 7, 2010 | 02:27 PM
Maluko's Avatar
or both.
Old Jan 7, 2010 | 10:20 PM
punkdown's Avatar
You can try hooking up 12v to the remote terminal on your amp just to test your amp, just jump it to the 12v terminal with a short piece of wire. If that works than there is a problem somewhere between there and your head unit with the remote power.
Also to test the RCA's you can get a 3.5mm phono to rca adapter cable and use that to play an ipod or whatever through the amp. That way you can narrow down the possible problems.
Stock90Civic
Audio / Security / Video
Mar 14, 2009 11:24 AM
boostedjdmdc2
Feb 23, 2009 05:08 PM
JdM_RACeR07
Nov 19, 2006 04:02 PM
notguilty411
15
Apr 5, 2005 01:56 PM
intenseEK
23
Dec 17, 2003 06:54 PM
