Alpine Type R 6.5 " components in CRX doors
Im having trouble getting these to fit because the window guide is in the way. Is there a way to get these in? Thanks
Old Fart
Re: Alpine Type R 6.5 " components in CRX doors (CoolRedXylophone)
Yes, you have to replace the stock plastic speaker housings with custom MDF housings, you may even have to space the front window guide back a little.
Or you can go the ghetto route and use depth reducer/spacers. 94
Re: Alpine Type R 6.5 " components in CRX doors (fcm)
plastic speaker housing? all i see is a hole in the door metal. how would one go about making a MDF housing, and could the stock plastic speaker cover fit over it?
also, i found these, http://www.crutchfield.com/S-H...27802
but would they help me at all?
sorry for my noobness, but thanks very much for the help
Modified by CoolRedXylophone at 9:39 PM 3/17/2007
Old Fart
They are rear speaker brackets for the 88-91 CRX.
The should look something like this... http://cgi.ebay.com/ebaymotors...QrdZ1
What was in the doors when you pulled the door panel, were they aftermarket speakers, are there screw holes other then the stock ones around the speaker opening? 94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">They are rear speaker brackets for the 88-91 CRX.
What was in the doors when you pulled the door panel, were they aftermarket speakers, are there screw holes other then the stock ones around the speaker opening? 94</TD></TR></TABLE>
the plastic housing for the 5.25" speakers had been removed and 6.5" Honda speakers were there held in with 3 screws i believe. im going to remove the door paneling to try to get a better idea of what you are suggesting. im just having trouble picturing it. thanks for the help
to fit them in my ej8 i had to enlarge the hole in the door metal a bit. then i made a 3/4" mdf spacer and screwed them right into that. the plastic speaker cover fit with slight modification with a dremel...not much though.
SECURITY
08-05-2005 04:39 AM
Kristo92
09-01-2003 12:59 PM
