alpine headunit problem.
Old Dec 5, 2004 | 09:06 PM
ilikemyaccord's Avatar
Default alpine headunit problem.
just installed an alpine 9827 headunit into my girlfriends 03 nissan xterra. it worked fine after install for 3 days then today, she calls and said it just died out on her. what would be the problem? check the wires again or for blown fuses? thanks for the help ...
Old Dec 6, 2004 | 07:38 AM
fcm's Avatar
fcm
Old Fart
Default Re: alpine headunit problem. (ilikemyaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikemyaccord &raquo;</TD></TR><TR><TD CLASS="quote">just installed an alpine 9827 headunit into my girlfriends 03 nissan xterra. it worked fine after install for 3 days then today, she calls and said it just died out on her. what would be the problem? check the wires again or for blown fuses? thanks for the help ...</TD></TR></TABLE>Yes check the wireing, also check the constant power fuse the one that is the memory for the OEM HU, if it is blown you will have to move the yellow constant power wire on the Alpine as it is not just memory, it is also power for the internel amp, best place is right to the batt. if that was the problem, the unit will sound a lot better with the yellow wired to the batt.
the Alpines amp has 3 or 4 times the watts that the OEM HU has, so it also needs 3 or 4 times more power to run properly, the stock memory wire can't deliver that. 94
Old Dec 6, 2004 | 09:40 AM
Default Re: alpine headunit problem. (fcm)
ill try that..thanks
Old Dec 7, 2004 | 04:50 PM
yea, the fuse blew so we replaced it and electrical taped up the extra wires. i dont understand why re routing the yellow wire directly to the battery would help since wouldnt the yellow wire already hooked up to the harness connect to the battery itself? thanks for the help. and i was wondering what could be the cause for the fuse to blow in the first place? thanks alot.
Old Dec 7, 2004 | 08:37 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikemyaccord &raquo;</TD></TR><TR><TD CLASS="quote">yea, the fuse blew so we replaced it and electrical taped up the extra wires. i dont understand why re routing the yellow wire directly to the battery would help since wouldnt the yellow wire already hooked up to the harness connect to the battery itself? thanks for the help. and i was wondering what could be the cause for the fuse to blow in the first place? thanks alot.</TD></TR></TABLE>The fuse went because the HU needs more power, [yellow wire] then it can get from the OEM radio harness, that constant power was ment as a memory, [presets and clock] only, the internal amp on the Alpine HU needs way more power, that is why running the yellow to the batt, [ just like you do with any amp] will solve the problem , it will sound better also, when we do a highpower Hu Alpine, Clarion, Eclipse, we run a fused 10ga wire from the batt. to behind the HU, and connect the yellow to that. 94
Old Dec 7, 2004 | 09:06 PM
how would i get through to the firewall to put the yellow wire to the battery? i usally just go around the sloppy way for my car but id like to make it clean for my girlfriend's ride. and would doing this solve the fuse might getting blown again? thanks
Old Dec 7, 2004 | 10:20 PM
and this is what one of the audio experts on HT said..i didnt know this about the ground.
cheack all the fuses under the hood and dash. then pull the radio, make sure the deck has power, ignition and ground. nissans don;t have a ground in the factory wiring harness. you may have to make a ground wire, just screw a piece of wire onto the metal dash brase, and hook it to the deck. make sure to check the fuse on the back of the deck. good luck.
Old Dec 8, 2004 | 07:22 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikemyaccord &raquo;</TD></TR><TR><TD CLASS="quote">and this is what one of the audio experts on HT said..i didnt know this about the ground.
</TD></TR></TABLE>Yea.... just like the powe , [ yellow] the ground has to be good, but like he said Nissan normaly don't have grounds in the OEM radio harness, and I would assume you ran the Hu ground to the chassis, [evan if you used an adpt. harness that has a black ground in it , and evan if the Nissans radio harness has a ground, you still need to ground to the chassis]
As for getting the wire through the firewall, there a number of grommets for wireing and cables in the firewall, maybe evan some unused "dummy" plugs use one of them, or drill a hole and install a grommet 94
DCshoecompany
Audio / Security / Video
Aug 11, 2008 01:22 AM
notguilty411
23
Aug 13, 2005 07:22 AM
lude_behavior
Nov 25, 2004 07:10 AM
2K GSR
Jan 15, 2004 08:46 PM
