Alpine is crap!!
Old Nov 27, 2004 | 04:58 PM
  #26
ATF Kuk's Avatar
Default Re: (rcurley55)
any updates on ur M3?
Old Nov 27, 2004 | 04:59 PM
  #27
GSteg's Avatar
Default Re: (EBP_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">i've had a 7995 for about 3 years now i think and its been problem free.</TD></TR></TABLE>
wait til next year.....
jk
i cannot seem to tackle the problem! i need to isolate!!!!!!
i'm going to need some test tones. gonna hook up a DMM to the RCA output to see if i get any voltage on that thing. if i do, then i know my problem is somewhere else.
what was the problem again? radio works, but when in CD mode, no sound comes out of the speakers. i know it's not my amp because it would not make sense for it to only produce radio signals and crap like that.
i think it's because atf kuk touched me a few weeks back
Old Nov 27, 2004 | 05:17 PM
  #28
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: (GSteg)
It doesn't have two remote turn on leads in the harness does it?
Old Nov 27, 2004 | 05:21 PM
  #29
GSteg's Avatar
nope. only one.
the thing is...about last year, i hooked it up in my mom's van and it worked fine. i even hooked it up to a road gear amp and it worked fine.
but for some reason, it doesn't work in my car a year later....
Old Nov 27, 2004 | 07:06 PM
  #30
rcurley55's Avatar
New User
Default Re: (ATF Kuk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATF Kuk &raquo;</TD></TR><TR><TD CLASS="quote">any updates on ur M3?</TD></TR></TABLE>
yeah, kicks are in, fuses wired up, amprack almost finished, sub box is bolted in, a-pillars have been glassed, and the trim piece for the dash is ready for paint
I have to strip the car this week (waiting for parts) so that I can wire it up, then it's full steam ahead
Old Nov 27, 2004 | 07:43 PM
  #31
GSteg's Avatar
crap. i was thinking about running kick panels, but i still face the same problem....i have to mount the horns upside down so that means no kick.
I could use a go cart right now.
Old Nov 27, 2004 | 07:57 PM
  #32
ATF Kuk's Avatar
Default Re: (GSteg)
u can use a good luck charm, maybe it will drive the bad luck out of u, U JINX.
Old Nov 27, 2004 | 10:04 PM
  #33
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
I sell Alpine... I'm even an authorized Alpine F#1 Status dealer...
Alpine is very feature packed and has awesome sound quality and tuneability. Very innovative Ai-Net integration system.
CVA monitors always had motorization problems.
DVA dvd players always had playback and eject issues.
Pre MP3 era CD players had skipping and CD-R playback issues.
Cassette players kick ***.
All 2004 models from 9831 and above have glitches with playback and intermittent power.
V12 series amplifiers are the most reliable and good sounding amps out there.
Flex and VPower series amps have xover problems. Too much mid bass pass through causing tweeters to pop and crackle.
SPS series speakers tweeters blow often.
Old Nov 27, 2004 | 10:05 PM
  #34
ScareyH22A's Avatar
Community Builder
Default Re: (GSteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSteg &raquo;</TD></TR><TR><TD CLASS="quote">
jk
i think it's because atf kuk touched me a few weeks back </TD></TR></TABLE>
You've got your amps hooked up to the power antenna wire. Connect them to the amp turn on wire.
Old Nov 27, 2004 | 10:43 PM
  #35
GSteg's Avatar
Default Re: (ScareyH22A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A &raquo;</TD></TR><TR><TD CLASS="quote">You've got your amps hooked up to the power antenna wire. Connect them to the amp turn on wire.</TD></TR></TABLE>
why does everyone say this
they are hooked up properly as i am able to listen to the radio and the antenna goes up when i turn it on and it goes down when i go to CD mode. unless acura didn't label their wires correctly....
Old Nov 27, 2004 | 10:46 PM
  #36
GSteg's Avatar
oh wait..scareyh22..just remember..ur the one that is the assistant manager (am i right?) at beach autosound!
10K2HVN said that u had the TRU copper amp hooked up right now. is it still there or is it gone? my dad works at honda world so i could probably drop by sometimes
Old Nov 28, 2004 | 06:33 PM
  #37
ScareyH22A's Avatar
Community Builder
Default Re: (GSteg)
What copper amp?
Old Nov 28, 2004 | 06:34 PM
  #38
ScareyH22A's Avatar
Community Builder
Default Re: (GSteg)
But do you have your amplifiers hooked up to the same antenna wire? Because if they were, the sound would only come out when your radio is on.
Old Nov 28, 2004 | 06:44 PM
  #39
GSteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A &raquo;</TD></TR><TR><TD CLASS="quote">What copper amp?</TD></TR></TABLE>
wait..u work at beach autosound right?
if not, wrong dude
Old Nov 28, 2004 | 06:45 PM
  #40
GSteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A &raquo;</TD></TR><TR><TD CLASS="quote">But do you have your amplifiers hooked up to the same antenna wire? Because if they were, the sound would only come out when your radio is on.</TD></TR></TABLE>
the remote wire from the amp is connected to the headunit's ble/white wire while the power antenna is connected to the solid blue wire.
i'm pretty sure i got it hooked up right. the amp is still on when i'm in CD mode
Old Nov 28, 2004 | 09:31 PM
  #41
integra-modder's Avatar
Default Re: Alpine is crap!! (snoochtodanooch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">wow, i can't beleive you just dissed alpine and said a sony was good. Not even so much that you dissed alpine, but you said SONY WAS GOOD! lol. </TD></TR></TABLE>
Im sitting in a lounge at the airport and started laughing too loud...people looked at me funny...
I love my more than 2 year old alpine components and recently acquired amps...
Pioneer gets my HU money.
Old Nov 29, 2004 | 05:24 PM
  #42
EBP_SI's Avatar
Default Re: Alpine is crap!! (integra-modder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder &raquo;</TD></TR><TR><TD CLASS="quote">
Pioneer gets my HU money.</TD></TR></TABLE>
i dont know whats so funny about that statement. the older ES line blows away just about everything on the market right now for pure SQ. the xplode line is a different story.
so GSteg, my question is, you think i should stay away from the 7990??
Old Nov 29, 2004 | 05:38 PM
  #43
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: Alpine is crap!! (EBP_SI)
I have been leaning toward the upper level of Eclipse models, but due to recent reviews I have seen(one of which was on here), I may wait until the problems are fixed.
Old Nov 29, 2004 | 08:20 PM
  #44
tub_sephiroth's Avatar
Is it just me or does the illumination on the alpine decks prone to blow out? I have experienced this many times and am left with a working deck with a black display.
Old Nov 29, 2004 | 10:58 PM
  #45
coconutsoldier's Avatar
Default Re: (tub_sephiroth)
I have never liked sony. Had to many problems with their **** as a kid. Alpine
looked like they sell their **** based on how fancy they can make it. I would try
Kenwood, a Kenwood hu came in my car and it looked over four years old and
worked perfectly. I also think Panasonic is good. They don't skip as easily as kenwood hu's when you hit bumps going pretty fast, and have never had any problems with them.
Old Nov 29, 2004 | 10:59 PM
  #46
iiilgsrlll's Avatar
Default Re: (GSteg)
All of my decks have been Alpines and never had a single problem. Everything from tape pullouts back in the day, double-dins, to the top of the line decks they put out the last couple of years. Might just be luck of the draw but if that's the case you must have really bad luck.
Old Nov 29, 2004 | 11:16 PM
  #47
GSteg's Avatar
so GSteg, my question is, you think i should stay away from the 7990??</TD></TR></TABLE>
i have no idea. scareyh22a would be the better person to ask since he is an authorized F#1 dealer. He should know more about the reliability of those things than i do. Now what would u be doing with a 7990?????
Old Nov 30, 2004 | 01:13 PM
  #48
Enrikez's Avatar
Default Re: Alpine is crap!! (GSteg)
i have also had an Alpine 7930,comp unit from back in like 98...paid 450. worked about a year and a half. Then bought a Sony ES...awesome unit, never skipped( and i mean i've thrown some shitty cd's in there) and was greta quality. sucks they dont make ES anymore for car audio or i would of bought one instead of getting my Alpine 7897. good unit.....so far.
Old Nov 30, 2004 | 02:42 PM
  #49
The Alchemist...
Guest
Posts: n/a
I have just about every brand of head unit and I can say that Alpine is the best quality for the money. Alpine and Eclipse are the only two that I would personally go with.
Old Nov 30, 2004 | 05:32 PM
  #50
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSteg &raquo;</TD></TR><TR><TD CLASS="quote">Now what would u be doing with a 7990????? </TD></TR></TABLE>
well i was hoping it would make my lunch in the mornings.
