Alarm question
I have a 1994 integra gsr, I have a clarion cd player installed a while ago. After working on the car, it wouldnt start up. Now the car wont start and the cd player wont work (no power) I was wondering if it could be the anti theft system (stock acura alarm) could be causeing the problems. It ran fine like 2 weeks ago. It turns over but will not fire up
I really wasnt doing anything to any wire or harness. I was wondering becuase of my cd player not working would that cause the alarm to not work, which would not let my car start up. Or vice versa. It turns over but wont start. The clock and gaues, and interior lights work, but no cd player
quick question for you all. I have the stock/optional acura security system, will my car crank if the alarm or kill is activated? Does the cd player need to work in order to get the alarm to work properly?
the CD player will have nothing to do with the factory alarm. It does sound like you somehow tripped the fuel pump cut off, or have blown the fuel pump fuse? Best thing to do is pull out a spark plug and see if you're getting a spark. If not then it's something with the distributor, plugs, wires.... and that's not something the alarm will shut down. If you are getting a spark, smell the exhaust and/or the spark plug hole and see if you can smell fuel. If there is no fuel it's something related to the fuel pump. Either the pump went bad, the fuel pump relay died, a fuse blew, or the alarm's fuel cut kicked on.
imadigitalgod
Oct 31, 2004 09:11 AM
NewHonda01
Aug 24, 2004 05:24 AM
Quad-Damag
Audio / Security / Video
11
May 13, 2003 03:37 PM
