alarm led
Old Jun 12, 2004 | 10:06 AM
DieMaster's Avatar
Needs to be About 20% Cooler
Default alarm led
I'm not sure if this goes in sercurity, tech, or this fourm.
Where would be the best spot to put a alarm led in the dash?
Old Jun 12, 2004 | 10:10 AM
EL Vap133's Avatar
Default Re: alarm led (JC18)
Wherever it is most visible for someone to see it from the outside of your car.
Old Jun 12, 2004 | 10:17 AM
DieMaster's Avatar
Default Re: alarm led (EL Vap133)
where would that be? the blanks down by the ignition swich? the gagues? the center vents?
where is yours?
Old Jun 12, 2004 | 11:32 AM
sopiwnykg's Avatar
I have mine on the steering wheel body cover. A friend of mine has his on by his shifter. Those are probably the most common places to put them
Old Jun 12, 2004 | 04:53 PM
GotGSR's Avatar
Default Re: alarm led (sopiwnykg)
in between the hazard and rear defroster buttons on an integra...drill a hole and woila!
Old Jun 12, 2004 | 06:01 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sopiwnykg &raquo;</TD></TR><TR><TD CLASS="quote">I have mine on the steering wheel body cover. A friend of mine has his on by his shifter. Those are probably the most common places to put them</TD></TR></TABLE> steering wheel body cover very visible 94
Old Jun 14, 2004 | 03:57 PM
DieMaster's Avatar
Default Re: alarm led (fcm)
could i get some more ideas please
pics too!
Old Jun 14, 2004 | 06:54 PM
B18C_EJ8's Avatar
On my '98 Civic, I drilled a hole in the top of my gauge cluster, and the led is mounted upside down in that hole... Very obvious almost 360 degrees around the car..
Old Jun 14, 2004 | 11:25 PM
7thGenAccord's Avatar
off topic but just wondering is it hard to change the LED ??/ i wanna change mine to blue
Old Jun 15, 2004 | 04:52 AM
itr_dc2's Avatar
Default Re: (K24A4)
i have mine mounted on the steering column, and a led scanner mounted on the rear view mirror.
Old Jun 15, 2004 | 04:53 AM
itr_dc2's Avatar
Default Re: (K24A4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K24A4 &raquo;</TD></TR><TR><TD CLASS="quote">off topic but just wondering is it hard to change the LED ??/ i wanna change mine to blue</TD></TR></TABLE>
What alarm do you have, and where is it mounted?
It doesnt really matter what alarm you have, just throw in the new led, soldier and tape up the new wires and you are done.
The reason i asked to what alarm you have is, because if anyone has some extra alarm LED's laying around like i do, you can just plug a new one into the brain and voila.
Old Jun 15, 2004 | 07:00 AM
fcm's Avatar
fcm
Old Fart
Default Re: (itr_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
The reason i asked to what alarm you have is, because if anyone has some extra alarm LED's laying around like i do, you can just plug a new one into the brain and voila.</TD></TR></TABLE> YES it does matter . Alarms can use 1volt to 12volt leds using, using lower volt led will just blow led, using higher volt led can blow led output of alarm. 94
androO
Audio / Security / Video
Jun 7, 2008 09:48 AM
SilverWarrior
Jun 4, 2007 09:23 AM
Frost_1097
Jan 16, 2007 03:48 PM
Thirty-Nine
May 30, 2003 11:08 AM
92CIVICCX
Mar 9, 2003 04:34 PM
