Alarm help please
Old Jan 3, 2005 | 12:04 AM
needaimport's Avatar
Default Alarm help please
ok so today i hooked up my amp/subwoofer. and went to walmart. the alarm red led thingy starts to flash. i didnt even know my car had an alarm. (no remote)and im like wtf ive never seen that flash before. and then when i get back to my car. i put the key in unlocked the door, and open it. the alarm starts going off and the corners lights flash. i tried to put the key in the ignition and start it. but the alarm was triggered so it wouldnt start. i panicked so i ripped out the cord to the alarm horn. that stopped the sound. then i ripped out the alarm box. well at least i think it was the alarm box. its the a box a lil smaller than a pack of cigarettes. it had a red, blue and black wire run into it. and i tore those wires out. also there was a small red LED flashing on it. and a **** that a friend said was for the alarms sensitivity. it didnt help. the horn stopped but the alarm kept going off. and i kept sticking my key in the ignition and try to turn on the car but it wouldnt work. so i disconnected the negative. and then i am able to start the car. but little red alarm light is on. so once i turn it off and open the drivers side door. the alarm goes off again.
well then i disconnect the negative and drive home.
so now wtf do i do? can someone help me?
my car is a 1994 honda civic hatchback dx.
help please. btw i <3 honda tech but just recently joined. and i am only 16 just letting people know.
Old Jan 3, 2005 | 07:32 AM
fcm's Avatar
fcm
Old Fart
Default Re: Alarm help please (needaimport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by needaimport &raquo;</TD></TR><TR><TD CLASS="quote">ok so today i hooked up my amp/subwoofer. and went to walmart. the alarm red led thingy starts to flash. i didnt even know my car had an alarm. (no remote)and im like wtf ive never seen that flash before. and then when i get back to my car. i put the key in unlocked the door, and open it. the alarm starts going off and the corners lights flash. i tried to put the key in the ignition and start it. but the alarm was triggered so it wouldnt start. i panicked so i ripped out the cord to the alarm horn. that stopped the sound. then i ripped out the alarm box. well at least i think it was the alarm box. its the a box a lil smaller than a pack of cigarettes. it had a red, blue and black wire run into it. and i tore those wires out. also there was a small red LED flashing on it. and a **** that a friend said was for the alarms sensitivity. it didnt help. the horn stopped but the alarm kept going off. and i kept sticking my key in the ignition and try to turn on the car but it wouldnt work. so i disconnected the negative. and then i am able to start the car. but little red alarm light is on. so once i turn it off and open the drivers side door. the alarm goes off again.
help please. btw i &lt;3 honda tech but just recently joined. and i am only 16 just letting people know.
</TD></TR></TABLE>You will have to remove the rest of the alarm, what you ripped out was the wires to the shock sen., follow the wires to the alarm brain, then unplug the the brain, it will be a box bigger then a pack of cigarettes and will have more then one set of wires pluged into it, unplug the one with the red wire with the fuse in it. 94
Old Jan 3, 2005 | 03:47 PM
polymath's Avatar
If you just rip the alarm out with the starter kill, you'll leave the starter wire open and it won't crank.
Be sure and reconnect the thicker gauge black wire with white stripe coming from the key cylinder. It should be spliced to a relay (the starter kill).
Old Jan 4, 2005 | 09:05 AM
S2L's Avatar
S2L
Default Re: Alarm help please (Coyote1800cc)
most alarm places will not wire the starter kill to be normally open so just taking out the alarm system itself should be fine. But in the event that the car still does not start, then you will need to reconnect the starter wire which is the thicker black/white trace wire under the dash.
raphael
Audio / Security / Video
Dec 27, 2007 11:30 PM
Glen Tennis
21
Aug 17, 2007 08:27 AM
egturtle
Apr 21, 2006 08:14 PM
97Alex
Jan 29, 2004 04:32 PM
upNover
Jun 11, 2002 08:30 PM
