Airspace question.
Old Feb 3, 2005 | 10:18 PM
rtpassini's Avatar
Default Airspace question.
anybody good with this?
i need to figure out the specs for the glass enclosure im going to be making.
there going to be inverted
sub specs (i have 2 of the Alum12q's):
im going ported.
also, should which way should i wire these. parallel-parallel, series-parallel, or series-series.
i think im series parallel right now....
Old Feb 4, 2005 | 04:36 AM
B18C_EJ8's Avatar
You need more detailed specs. You need a spec sheet with the Vas on it... That will tell you how much airspace those subs need...
Old Feb 4, 2005 | 04:37 AM
B18C_EJ8's Avatar
And your wiring question depends on your amp and what it can handle...
Old Feb 4, 2005 | 07:44 AM
rtpassini's Avatar
my amp sucks. i need a better one. but stereo is 2-4 ohms and bridged is 4-8.
heres some better specs (alum12q's)
http://www.audiobahninc.com/te...s.pdf
Old Feb 5, 2005 | 07:36 AM
rtpassini's Avatar
anyone?
Old Feb 6, 2005 | 08:51 AM
swaytec360's Avatar
Default Re: (rtpassini)
well right off the bat wiring 2 6 ohm woofers is going to make a weird resistance if your amp can go to 1ohm bridged your would parallel the coils then the woofers together bringing you to 1.5 ohms or if your amp wants 4ohms bridged you could series the coils making them both be 12 ohm and the parallel them together bringing them down to 6 but ideally you should get the third woofer so wether you paralled the whole circuit it would be 1ohm or seriess paralled would be 4ohm and yeah those specs dont say vas or any cu ft recomendations
Old Feb 6, 2005 | 12:55 PM
fcm's Avatar
fcm
Old Fart
Default Re: (swaytec360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swaytec360 &raquo;</TD></TR><TR><TD CLASS="quote">well right off the bat wiring 2 6 ohm woofers is going to make a weird resistance if your amp can go to 1ohm bridged your would parallel the coils then the woofers together bringing you to 1.5 ohms or if your amp wants 4ohms bridged you could series the coils making them both be 12 ohm and the parallel them together bringing them down to 6 but ideally you should get the third woofer so wether you paralled the whole circuit it would be 1ohm or seriess paralled would be 4ohm and yeah those specs dont say vas or any cu ft recomendations </TD></TR></TABLE>1.5ohms would be ok for a 1ohm stable amp, also vas is given in both liters and cu ft in posted spec sheet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtpassini &raquo;</TD></TR><TR><TD CLASS="quote">anybody good with this?
im going ported.
i think im series parallel right now....</TD></TR></TABLE> Every thing you need is on the audiobahn site 94
jpangeles
Audio / Security / Video
Dec 24, 2008 06:09 PM
x_tc-Dae
Dec 12, 2004 10:29 AM
GroundZer0 336
Apr 17, 2004 08:54 AM
shipsaeki
Jun 1, 2003 07:19 AM
GroundZer0 336
May 3, 2003 06:07 AM
