whats up wit the sub?
Old Feb 6, 2005 | 11:24 AM
hookedonvtec's Avatar
Default whats up wit the sub?
alright so last night the sub was working fine and today it wont work. it had power but it wasnt sending anything to the sub. the power then went off and i cant get it to turn back on. i dont think the amp blew but the ground came disconnected for like 2 seconds and i put it back on. the power to the amp was off while that happen but i dont know. im lost on what i should be checkin for. any suggestions?
Old Feb 6, 2005 | 12:25 PM
fcm's Avatar
fcm
Old Fart
Default Re: whats up wit the sub? (hookedonvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hookedonvtec &raquo;</TD></TR><TR><TD CLASS="quote">alright so last night the sub was working fine and today it wont work. it had power but it wasnt sending anything to the sub. the power then went off and i cant get it to turn back on. i dont think the amp blew but the ground came disconnected for like 2 seconds and i put it back on. the power to the amp was off while that happen but i dont know. im lost on what i should be checkin for. any suggestions?</TD></TR></TABLE> Check the sub, disconnect it from the amp, and check with a multimeter, if you don't have one, just use a batt., [9v works best] just touch the pos. and neg. of the batt. to the pos. and neg. of the sub, it will "pop", this does not mean the sub is good, only that there is continuity and it should make sound, if this is so, then the problem may be in the amp or HU, one thing I would look at is the sig. input on the amp or sig. output on the HU, mainly the sig. grounds, if an amp has the power wire hooked up and the groung is disconnected, even for a sec., the amp will "try" to get its groung through the sig. ground, and its tot near big enough and the tracer on the circuit board will blow like a fuse, it may happen in the amp or the HU, depends on the thickness of the tracers in the amp and the HU. 94
Old Feb 6, 2005 | 03:08 PM
Default Re: whats up wit the sub? (fcm)
ill try that. thanks man. anyone second that?
tca0bell
Audio / Security / Video
Feb 27, 2005 09:17 AM
Supta
Nov 16, 2004 05:59 PM
jv144
Jun 1, 2004 06:57 PM
GroundZer0 336
Aug 14, 2003 06:49 PM
Dr Pooface
37
Jun 5, 2002 08:02 PM
