adhesive foam for extra seal on sub boxes?
Old Jul 18, 2004 | 09:34 PM
CrazyModGSR's Avatar
Default adhesive foam for extra seal on sub boxes?
I am building a few enclosures w/ 3/4" MDF and plexi. Anyway, when putting the pieces together, I found that there are a few very small gaps between the MDF, even when screwed together and w/ liquid nails. I am wondering if I can use some kind of adhesive foam in place of the liquid nails which would, I assume, fill in the small spaces I have. I will still seal well w/ silicone. Any suggestions on what to use or where to get it?
Thanks
Old Jul 18, 2004 | 10:50 PM
shyboy817's Avatar
i had alot of holes and gaps that air was getting through, i used a large amount of liquid nail and it sealed it up real good
Old Jul 19, 2004 | 08:46 AM
fcm's Avatar
fcm
Old Fart
Default Re: adhesive foam for extra seal on sub boxes? (CrazyModGSR)
How are you cutting the MDF for the box that would leave gaps? 94
Old Jul 19, 2004 | 10:24 AM
Default Re: adhesive foam for extra seal on sub boxes? (fcm)
I have a small circular saw that I am using (used) by hand w/out a guide (because the guide wasn't long enough). I tried to cut as straight a line as possible, but as I said, there is a small, probably less than 1/16 of an inch gap at the end where the boards meet.
Old Jul 19, 2004 | 11:33 AM
sopiwnykg's Avatar
Resin the inside of the box to seal it. That would probably be the easiest way to do it.
Old Jul 19, 2004 | 12:08 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyModGSR &raquo;</TD></TR><TR><TD CLASS="quote">I have a small circular saw that I am using (used) by hand w/out a guide (because the guide wasn't long enough). I tried to cut as straight a line as possible, but as I said, there is a small, probably less than 1/16 of an inch gap at the end where the boards meet. </TD></TR></TABLE>
OIC Try this , when I have to make a cut with a circular saw, [ I do have a table and radial arm saw in my shop] I will use the edge of a sheet of MDF as a guide, butting the edge of the saws bottom plate up against it, you get a pretty good cut that way,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sopiwnykg &raquo;</TD></TR><TR><TD CLASS="quote">Resin the inside of the box to seal it. That would probably be the easiest way to do it.</TD></TR></TABLE>
I also use fiberglass resin inside my sub boxs to seal the MDF, MDF is a very porous, surprise! and if you don't belive me pull your subs and seal the inside of the box , you can use most anything, but resin works best, [other then the spray"dynamats"]
Old Jul 19, 2004 | 02:10 PM
shyboy817's Avatar
mines, my dimensions was barely off
Old Jul 19, 2004 | 03:08 PM
bassisliffe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">
MDF is a very porous, surprise! </TD></TR></TABLE>
are you saying its good to coat the inside? that air can pass through mdf??
all the more reason to PORT
Old Jul 20, 2004 | 07:47 AM
fcm's Avatar
fcm
Old Fart
Default Re: adhesive foam for extra seal on sub boxes? (bassisliffe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe &raquo;</TD></TR><TR><TD CLASS="quote">
all the more reason to PORT </TD></TR></TABLE>
Yes it is, yes it can.
Even more important that a ported box be airtight [everywere except the port, bassisliffe,] DAH. 94
Old Jul 21, 2004 | 07:18 PM
Even more important that a ported box be airtight [everywere except the port, bassisliffe,] DAH. 94</TD></TR></TABLE>
how can a ported box be air tight?
Old Jul 21, 2004 | 09:01 PM
fcm's Avatar
fcm
Old Fart
how can a ported box be air tight? </TD></TR></TABLE>
If air can leak out of the box anywere but at the port, how do you tune the port
And bass, I said [ everywere except the port] just for you, because I just knew you were going to ask,
[QUOTE=bassisliffe]
Take a shopvac stick it up to [ even 1 inch] MDF , drop some sawdust [ on other side , or if you have a sub in a box , and we know you do, listen, pull sub and seal, listen again
silentblackhat
Audio / Security / Video
Mar 8, 2006 05:37 AM
CrazyModGSR
Jul 15, 2004 08:21 PM
initialvtec
19
May 29, 2004 06:51 PM
Starrman85
Apr 2, 2003 12:46 PM
93civdx
Dec 14, 2002 05:06 PM
