adding power door locks to vx civic hatch....
Old Jan 18, 2002 | 05:52 AM
cjb92's Avatar
Default adding power door locks to vx civic hatch....
I would like to eliminate the external key hole for the door by using the 4dr EG rear door handles. I currently have an alarm that I want to use to unlock/lock the doors with but what is out there besides getting the factory power door lock mechanism from the EX model. Any other companies out there that make power locks that could be used in conjunction with my alarm?
Old Jan 19, 2002 | 08:35 PM
CanadaCivicSIR's Avatar
New User
Default Re: adding power door locks to vx civic hatch.... (superflea)
Spal makes door lock actuators that work well for your car.
Old Jan 20, 2002 | 05:43 AM
Eric R's Avatar
Default Re: adding power door locks to vx civic hatch.... (CanadaCivicSIR)
Actually, the door actuators that spal makes for the door locks are not strong enough to work with the hatch latchin mechanism. Besides, they'll be harder to install. You need to look for a 10 to 15 lbs. capacity actuator in order to do the job well. Check with Audiovox, Electric Life, etc. to look for the actuator that works with cable machanisms.
EDIT: Correction, oops. I thought the fellow was talking about the hatch latching mechanism. For the door locks Spal actuators are great!
[Modified by '01ITR#950, 7:42 PM 1/20/2002]
Old Jan 20, 2002 | 07:56 AM
New User
Default Re: adding power door locks to vx civic hatch.... ('01ITR#950)
I have used Spal actuators in many vehicles and have had no problems. Honda have the easiest locking mechanisms around. Spal actuators even work on most domestic vehicles with hard locking mechanisms.
If you are shaving your handles I would recommend a different actuator for the door openers but for the locks this actuator is more then enough.
Old Jan 20, 2002 | 09:33 AM
cjb92's Avatar
what is the pricing and where can you get the spal actuators?
How about these listed on ebay, they go for about 20 bucks.
This will only be for the locking mechanish so no shaved handles here. I will be hooking it up to my alarm once I get the actuators... http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1322139250
Old Jan 20, 2002 | 04:23 PM
New User
You can get the actuators at any stereo shop they go for about 20 bucks.
JDM_SOHC
26
Mar 25, 2017 05:33 PM
lazii_boi08
14
Aug 22, 2007 02:14 PM
yoursupinehead
Sep 16, 2006 11:34 AM
percyv143
May 15, 2006 03:29 AM
mr 636
Feb 22, 2006 06:46 AM
