Accord's Stock Electrical System
Old Aug 26, 2004 | 09:20 AM
KamakazieX's Avatar
Default Accord's Stock Electrical System
Just wondering if anyone has had the same symptoms that i've had. I've got an Alpine CDM-7854, rigged up to a S15L7, ive ripped out all the wiring, found out the lights on the deck still dimm when its turned up. Wondering if I should run a 10ga tap to the cd player /w my .5 farad attached to it. Thinking that might solve the problem, and drop my own inline fuse in there maybe 30amp or none at all...
Anyone?
Old Aug 26, 2004 | 07:20 PM
fcm's Avatar
fcm
Old Fart
Default Re: Accord's Stock Electrical System (KamakazieX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KamakazieX &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering if anyone has had the same symptoms that i've had. I've got an Alpine CDM-7854, rigged up to a S15L7, ive ripped out all the wiring, found out the lights on the deck still dimm when its turned up. Wondering if I should run a 10ga tap to the cd player /w my .5 farad attached to it. Thinking that might solve the problem, and drop my own inline fuse in there maybe 30amp or none at all...
Anyone?</TD></TR></TABLE> What is a "S15L7"? , if you are useing deck power to run the highpass speakers, then a 10 ga power wire from the batt. can't hurt, but fuse it, you will have to beef up the ground on the HU also, you can do that at the back of the HU, if you have an amp running a sub,[S15L7] make sure the amp has a good ground, and is getting enough power, you may have to beef up groung at the batt. and run a larger "charge" line from the alt. 94
Old Aug 26, 2004 | 09:33 PM
teamxtant's Avatar
Default Re: Accord's Stock Electrical System (fcm)
Correct me if I'm wrong. You have a Alpine CD Player hooked straight to an Kicker solo baric L7 with no amp?
Old Aug 27, 2004 | 07:50 AM
KamakazieX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamxtant &raquo;</TD></TR><TR><TD CLASS="quote">Correct me if I'm wrong. You have a Alpine CD Player hooked straight to an Kicker solo baric L7 with no amp?</TD></TR></TABLE>
I'd have one badass setup if I had something like that :-D
No I've got K693's for the rear, DX60's for the front... KX800.2 to run the rest :-p
Old Aug 27, 2004 | 11:58 AM
arrivalanche's Avatar
yea, if your running a kicker 800.2 expect everything in your car to dim. you need around 4 guage power and ground for that amp and probably a bigger alternator that what a honda would come with to solve your prob completely.
Old Aug 27, 2004 | 06:42 PM
fcm's Avatar
fcm
Old Fart
Default Re: Accord's Stock Electrical System (arrivalanche)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arrivalanche &raquo;</TD></TR><TR><TD CLASS="quote">yea, if your running a kicker 800.2 expect everything in your car to dim. you need around 4 guage power and ground for that amp and probably a bigger alternator that what a honda would come with to solve your prob completely.</TD></TR></TABLE> Dito that. 94
mister_r0b
May 19, 2012 07:34 PM
h22_crx
12
Mar 15, 2007 05:33 PM
Yoshiemaster
Honda Civic (2001 - 2005)
Aug 12, 2006 01:12 PM
jamie_honda_08
Audio / Security / Video
Oct 22, 2004 09:57 PM
