? about installing an amp
Old Jan 16, 2006 | 07:06 AM
skata89's Avatar
Default ? about installing an amp
key in the diagram that came with the amp, it doesnt show a fuse on the 12v wire that goes from the battery to the amp. does that mean i dont need one cuz there are 2 fuse on the amp itself. thanks for the help.
Old Jan 16, 2006 | 07:33 AM
hb420's Avatar
you should always have a fuse on the power cable going to the battery
Old Jan 16, 2006 | 07:36 AM
skata89's Avatar
Default Re: (hb420)
ight thanks. and how do you know wut sixe amp to use?
Old Jan 16, 2006 | 08:22 AM
Iamcuddles's Avatar
Default Re: (skata89)
See how many fuses your amp is holding and the rating on those. You want nothing less than that. Also mount your fuse within 1 foot of the batt.
Old Jan 16, 2006 | 11:38 AM
. O M E G A's Avatar
3rd g3aR vTak
Default Re: (Iamcuddles)
True story^^^
Old Jan 16, 2006 | 12:59 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skata89 &raquo;</TD></TR><TR><TD CLASS="quote">ight thanks. and how do you know wut sixe amp to use?
Fusing depends on the wire size. Its a huge misconception that the fuses are there to protect the equipment. Fusing is there to protect the wiring and thats why under the hood, you should fuse your main power cable as close as possible.
farhat civic eg
Audio / Security / Video
Jun 6, 2011 05:18 AM
zerovandez
Mar 8, 2008 01:30 PM
92ehatch
13
Nov 30, 2005 08:07 AM
casmello
Oct 6, 2005 10:41 AM
ilikemyaccord
Aug 13, 2004 04:36 PM
