998T Bitwriter ERROR help please?
Old Nov 23, 2009 | 09:37 AM
Karado58's Avatar
Default 998T Bitwriter ERROR help please?
Viper 5002
1998 Honda Civic
I'm trying to change H2/7 to Constant with a 998T Bitwriter, but get this error:
"A transmitter must be programed into the unit..."
Thank you.
-Joseph
Old Nov 23, 2009 | 02:48 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: 998T Bitwriter ERROR help please?
On your alarm brain there has to be a remote programmed into the brain for it be used. On some alarms the remote is not pre-programmed into the brain. Or the if the alarm is new. You must use the remote for the first time. Also if you do not have the newer version of the bitwriter with the chip upgrade. It will not read the newer alarms systems.
Old Nov 23, 2009 | 06:42 PM
Karado58's Avatar
Got it...working now.
2 other issues:
1. 507M Tilt Sensor is reporting as Trunk on remote. I did do a Diode Isolate.
2. Blue light does not work. I had to extend it, and I used solid 22g wire. Would this matter? I did check wiring.
Thanks
EMILYKHAMPOU
Audio / Security / Video
17
Dec 21, 2014 09:15 AM
ejpogi1925
Mar 2, 2009 11:50 AM
cambodia got civics too
Nov 5, 2005 05:21 PM
Hypertek99
Jan 6, 2005 07:34 AM
