Amp protected light is on???
Old Nov 23, 2009 | 09:09 PM
avaldez's Avatar
Default Amp protected light is on???
Im connecting a sound system in my car and the subwoffers dont turn on. I have good power, a good remote, and good ground. I used a test light so I know the follwing is all good. For some reason there is no power out of the amp speaker exits. Any ideas on wat i should do??? Theres also a protected red light that is on.
Old Nov 23, 2009 | 09:25 PM
dohcvtak's Avatar
Default Re: Amp protected light is on???
well.. without anything connected to the amp except power ground and remote if it automatically go into protection mode most would say the amp is a gonner...
Old Nov 23, 2009 | 10:26 PM
avaldez's Avatar
ill try that.. wat if it goes in protection mode with rca wires?
Old Nov 24, 2009 | 06:16 AM
fcm's Avatar
fcm
Old Fart
What is the make and model of the amp?
If a protection light is on on an amp with no speakers connected to it the amp, as mentioned, is toast, probably blown output stage. 94
Old Nov 24, 2009 | 11:09 AM
goi_ek's Avatar
rcas are just signal
Old Nov 25, 2009 | 11:30 AM
Eric R's Avatar
2x
Try that.
If it does it only when the speakers are hooked, there is a short in them. Meaning, a toasted voice coil (or voice coils). Check each sub individually with a ohm meter. Check the speaker connections in the box as well.
boostedeg302
Audio / Security / Video
Dec 29, 2007 10:01 PM
TeenyTymer69er
14
May 29, 2006 07:32 AM
sinfulj32
Oct 16, 2005 08:44 AM
CivicSiRracer69
Oct 18, 2003 04:25 PM
