98' teg boston speaker problem.
Old Sep 21, 2004 | 07:44 AM
98silverintegra's Avatar
Default 98' teg boston speaker problem.
Recently I bought a set of 5 inch boston speakers to go along with my new deck. after removing the factory speakers we found that the plastic cone that held the speaker would not allow the speaker to sit properly. we have attempted some modifications to one of the plastic 'speaker holders', and that has yet to work. I was just wondering if anyone has had any similar problems, and what I could do to fix this-other than getting them professionaly installed.
Old Sep 21, 2004 | 08:00 AM
B18C_EJ8's Avatar
Just do what everyone else does, and cut the basket out to allow the speaker to fit flush.. . Just be aware of depth restrictions, so the window doesn't hit the speaker when it opens...
Old Sep 21, 2004 | 08:03 AM
Default Re: (B18C_EJ8)
we have made quite a few modifications to the basket, and we are getting pretty close to the screw holes and it still has a-ways to go.
or did you mean, completely eliminate the basket by removing it?
Old Sep 21, 2004 | 08:12 AM
fcm's Avatar
fcm
Old Fart
Default Re: (98silverintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98silverintegra &raquo;</TD></TR><TR><TD CLASS="quote">we have made quite a few modifications to the basket, and we are getting pretty close to the screw holes and it still has a-ways to go.
or did you mean, completely eliminate the basket by removing it?</TD></TR></TABLE> Do not remove basket, cut hole in back big enough for speaker magnet to fit through, the teg takes a 6.5" speaker, if you have a 5" it should fit, and there are screw holes in basket that line up with the 5", you may not get a seal on the speaker, so you may have to make a "sealed ring", use 1/4" MDF, or 1/2" if you need some depth reduction 94
peteyb
Audio / Security / Video
Feb 22, 2012 06:20 AM
krystufer
Mar 15, 2009 07:52 PM
Mike1486
Jan 1, 2005 11:25 PM
GWInquisitor14
14
Dec 16, 2004 02:35 PM
Battousai TT52
Apr 11, 2002 07:18 PM
