96 integra amp hookup
Old Mar 31, 2019 | 01:54 PM
purposebuilt's Avatar
Default 96 integra amp hookup
Hi I was woundering what you would hook the blue wire upto on the radio. I have no blue wire on my radio harness is it just a wire to tell you the radio on can I just hook it up to the switched on power wire. I'm completly lost when it comes to radio wireing
Old Apr 1, 2019 | 09:20 AM
Alex98's Avatar
Default Re: 96 integra amp hookup
The blue wire is a turn-on wire for a separate amp. If you're not running a separate amp, just tape it off. If you plan on adding an amp later on, I'd hook up a length of wire to the blue wire on the harness as well as an RCA cable and either run it all the way back to the trunk, or just tuck it into the kick panel for now. It'll save you the time of tearing apart the console to get to the back of the radio.
Old Apr 2, 2019 | 05:28 AM
hondandy's Avatar
All it is a 12v positive when radio is turned on. Either makes the power ant. go up or kicks on an amp. Aftermarket head unit will have one or two wires for this purpose. Your oem harness has a wire going to the power antennae, you can look that up and tap into it. I wouldn't hack up the wiring in your car though, just get a harness adapter to make things easy. It will have a blue wire.
Old Dec 6, 2019 | 04:48 PM
Kobly's Avatar
The blue wire functions as a signal line when the radio is turned on which can be used to turn on other equipment such as your amps and equalizer, etc.
camelian
Jul 25, 2007 12:47 AM
sasser43
Audio / Security / Video
Jan 4, 2007 05:13 PM
kcivicboi
Feb 23, 2006 11:26 AM
boostincoupe
Oct 6, 2005 05:19 PM
XplodeTeg
Apr 6, 2005 09:56 AM
