96 civc ex keyless entry
Old Apr 23, 2003 | 11:16 PM
chankyeyes's Avatar
Default 96 civc ex keyless entry
Hey, just had a quick question. I had a audio dealer install my factory radio so i could have an aftermarket radio and still keep my keyless entry. The audio dealer said he installed the factor radio, but only the green plug is plugged into the factory radio. I thought that the other harness had to be plugged into it also. Any help would be cool. So my question is, should the factory radio be plugged into the harness and the green plug?
Curtis
Old Apr 24, 2003 | 02:07 AM
silvernole12's Avatar
Default Re: 96 civc ex keyless entry (chankyeyes)
I'm not too sure which plugs need to be in. But all you have to do is when you get your car back is check the keyless entry to see if it works. If it does then you're good to go, if not, tell them to fix it.
Old Apr 24, 2003 | 03:27 PM
chankyeyes's Avatar
hah, thanks, guess i will
Old Apr 25, 2003 | 08:36 AM
rjr162's Avatar
Default Re: (chankyeyes)
the factory radio needs the green plug plus power, ground, and accessory (which the Metra 70-1720T does)
Old Apr 25, 2003 | 09:33 PM
99_BlackSI's Avatar
Default Re: (rjr162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 &raquo;</TD></TR><TR><TD CLASS="quote">the factory radio needs the green plug plus power, ground, and accessory (which the Metra 70-1720T does)</TD></TR></TABLE>
Yup both plugs need to be plugged into the factory radio in order for the keyless entry and the domelight supervision to work correctly. Grab the Metra 1720T harness and you are all set
Dave
JHP
13
Mar 9, 2009 12:20 PM
JHP
Audio / Security / Video
Mar 9, 2009 02:57 AM
EeeJayEight
11
Jan 4, 2005 09:40 PM
playabill19
Jul 21, 2002 08:36 PM
