2ohm DVC, or 4ohm SVC?
Old Dec 3, 2008 | 06:55 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default 2ohm DVC, or 4ohm SVC?
same RMS power.. just wondering why people make single, and dual VC subs?
im on the market for a factory sub replacement for my car, right now it has a DVC 6.5"
since they're isn't alot of 6.5"s on the market, im stuck between 3 manufactures. pretty much same rms power..
kicker svc 4ohm
jl w3 svc 4ohm
elemental design dvc 4ohm
so since its a sinlge sub, my dvc 4 ohm is out.. can't wire it 4ohm final.
so im trying to understand.. do i get the same bang for the buck with single vc, as i would a dual vc? or does the DVC hog up more energy with 2 seperate VC's?
Old Dec 3, 2008 | 11:10 AM
fcm's Avatar
fcm
Old Fart
The main advantage with DVC subs is flexibility with wiring when using multiple subs, as for "same bang for the buck", assuming everything else is the same, [not likely] a 300W SVC would be the same as a 300W DVC in regards to the "energy" they would "hog up".
You should be looking for a sub in the wattage range and impedance needed, you do not need to worry if it is a SVC or DVC, just that the impedance load and wattage is correct.94
Old Dec 3, 2008 | 11:22 AM
Built B16A's Avatar
ok, i understand.. i asked another audio nut also, he said basically the same thing.
i was just figuring, imagine if you will, 2 engines in 1 car running, you prolly have great acceleration, and power, but when your coasting, your just wasting gas...
so i was thinking maybe a DVC would be great for power, but then just cruising, would suck more energy than a SVC... good to know.
Teawins21
Audio / Security / Video
Dec 3, 2012 12:39 AM
no_skillz
Oct 9, 2007 03:08 PM
N1NjA TuRtLE
Sep 25, 2006 05:21 PM
pnthr30
13
Jun 15, 2004 07:05 PM
Red Bull Man
Apr 27, 2004 05:22 AM
