2 ohm components?
Old Dec 15, 2005 | 10:24 AM
Spicoli v 3.0's Avatar
Default 2 ohm components?
Are there any component on the market that run at 2 ohms, if so where would i find them the only ones i see are running at 4 ohms only. Id like 2 ohms so i can run a set off my 2x75 rms amp insead of 4 ohms 2x50
Old Dec 15, 2005 | 10:45 AM
MLD211's Avatar
Default Re: 2 ohm components? (Spicoli v 3.0)
no not that i know of
Old Dec 15, 2005 | 11:45 AM
. O M E G A's Avatar
3rd g3aR vTak
You could use a resistor. But I don't see the point. With the extra 50 watts total , you not gonna hear a perceivable difference. You have to have at least double the power to "hear" a difference.
Old Dec 15, 2005 | 11:51 AM
Default Re: 2 ohm components? (omega02379)
i just don't want to get a set of 75-90 rms speakers if my amp is only 50 @ 4 ohms. and if i can find a set of 2 ohm 75 watts it would be a perfect match
Old Dec 15, 2005 | 11:54 AM
3rd g3aR vTak
Ratings are guidlines and not an exact science. It's not gonna make a huge difference. Your amp is not putting out a continuous 50 watts. Even if that is the RMS rating. It probably puts out a little more or a little less.
Old Dec 15, 2005 | 05:59 PM
incubus's Avatar
you also have to take into account the damping factor of your amp, which in laments terms is usable power. as your load decreases from 4 to 2 ohms your damping factor will also decrease which will give you less power than you expect all the while increasing distortion, which will be very noticable in your tweeters.
so your 25w rms increase per channel that you might gain, will probably only account to a few extra watts at the sacrifice of SQ.
In other words its not even worth you exerting anymore energy into researching this.
Old Dec 15, 2005 | 08:05 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spicoli v 3.0 &raquo;</TD></TR><TR><TD CLASS="quote">i just don't want to get a set of 75-90 rms speakers if my amp is only 50 @ 4 ohms. and if i can find a set of 2 ohm 75 watts it would be a perfect match</TD></TR></TABLE>
you could always get a set of components that can be bi-amped and then remove the bi-amp jumpers.
Old Dec 15, 2005 | 10:38 PM
nsxxtreme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spicoli v 3.0 &raquo;</TD></TR><TR><TD CLASS="quote">Are there any component on the market that run at 2 ohms, if so where would i find them the only ones i see are running at 4 ohms only. Id like 2 ohms so i can run a set off my 2x75 rms amp insead of 4 ohms 2x50</TD></TR></TABLE>Sure there is if you did some searching you find http://www.imagedynamicsusa.co...range
I am sure if you did some more searching you could find even more 2 ohm seperates.
Old Dec 15, 2005 | 10:57 PM
nsxxtreme's Avatar
Default Re: 2 ohm components? (incubus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incubus &raquo;</TD></TR><TR><TD CLASS="quote">you also have to take into account the damping factor of your amp, which in laments terms is usable power. as your load decreases from 4 to 2 ohms your damping factor will also decrease which will give you less power than you expect all the while increasing distortion, which will be very noticable in your tweeters.
In other words its not even worth you exerting anymore energy into researching this.</TD></TR></TABLE>What?????? Dampening factor represents the amplifiers ability to control the speaker. I wouldn't get hung up on dampening factor other then if you have a really low number you have a crappy amp. Dampening factor is to complex for most people to understand anyway. And it is not a constant number. It will change differently with different brands of speakers. It is speaker impedence/(amplifier output impedence) and we all know speaker impedence is not constant, although some speakers are better then others.
Old Dec 16, 2005 | 06:31 AM
GZERO's Avatar
Default Re: 2 ohm components? (nsxxtreme)
i saw some infinitys that are 2 ohms look around.
pbizzlegsr
Audio / Security / Video
Jun 28, 2007 08:00 PM
Problemo
Sep 24, 2003 10:35 PM
redman223
Jun 16, 2003 02:35 PM
o_O
Jan 24, 2003 10:39 AM
97GSR
Jan 28, 2002 07:22 PM
