Too much power to speakers?
Old Jan 23, 2003 | 12:26 PM
o_O's Avatar
o_O
Default Too much power to speakers?
Ok here's my question, I have a comp. set of Diamond Audio M661 speakers that can handle 20-170 Watts. I have a 4 channel Eclipse 32440 amp rated @ 4x85 W @ 4 ohms. I plan to bridge it giving me 2x240 W @ 4 ohms. Is this too much power for my speakers? I'll probably have to set the gains down. I have heard about having 'headroom'. could someone explain this please.
thanks
o_O
Old Jan 23, 2003 | 07:13 PM
Regular Series's Avatar
Default Re: Too much power to speakers? (o_O)
Well, it probably won't kill your speakers. You can feed most speakers a bit more power than the manufacturers recommend. You might shorten their useful life if you run them really hard. The other thing is that you'll only rarely hit 240 watts - consider that I can hit 110 db in my car with a 35w x 4 Crossfire running 4 6.5 JL VRs and a 200w Lightning to my MicroSub. Just for reference, 120 db is the threshold of pain. 110 db is still very dangerous.
The other thing to consider is that bridging your amp will give the sound a "rough" quality. The extra internal electronics get thrown into the mix in bridging add quite a bit of noise to the signal. You should have more than enough headroom at 85w RMS in a car - and better sound to boot. HTH.
Old Jan 23, 2003 | 07:20 PM
vteg's Avatar
New User
If you are worried and the speakers are bi-ampible you may be able to give them 85 each(170 per component set).
Old Jan 23, 2003 | 10:27 PM
cheezthis's Avatar
Default Re: Too much power to speakers? (vteg)
Definitely overpower them...
Wattage ratings on speakers are nothing more than the ability to properly dissipate heat. As long as the signal is clean, you really have nothing to worry about. I'd be more worried about underpowering and sending distorted signals to them than overpowering. This allows you to push the speakers well without pushing your amp. Go for it...
Old Jan 24, 2003 | 10:39 AM
o_O's Avatar
o_O
Default Re: Too much power to speakers? (cheezthis)
Thanks for the input, I'll bridge it and keep my gains down.
JohnnyEF
Audio / Security / Video
May 19, 2010 04:59 AM
musashiasano
11
May 18, 2009 02:58 PM
shutta
Jan 4, 2006 06:31 PM
GZERO
Dec 3, 2005 11:58 PM
GetSmoked
Mar 11, 2005 03:20 PM
