AMP/SUB question
Old May 24, 2006 | 01:58 PM
supracrx's Avatar
Default AMP/SUB question
ok in my other post i finished my enclosure. now i'm just trying to make the sound good. i have alpine CDA-7892 with the built in amp ot power speakers. then i have a Bazooka ELA300.1 which is rated at 300watts at 4 ohms. i have the Jl 10w3v2d2. supposedly its rated at max 300 watts at 4 ohms DVC. i wired the sub in series at 4 ohms and i'm currently running the amp to it and not turning it up a lot so i can break in the sub first. someone told me the amp is only pushing 150 watts? should i get a better amp? or is the other guy incorrect at saying 150 watts only?
also to adjust the amp settings do i mess with the min-max LEVEL **** which is basically the gain? then mess with the bass boost? what is the x-over on the amp? any help would be great thanks.
http://www.pricegrabber.com/se...05956
thanks a link to my amp with specs
Old May 24, 2006 | 03:13 PM
cynistersix's Avatar
Default Re: AMP/SUB question (supracrx)
you do not want your amp's max wattage to exceed the max rating on your speakers or you will blow them in due time. your friend was probably referring you to 150 watts being the RMS on the amp.
I run a 556 max watt audiobahn w12t on an amp that max watts at 550. keeping the system sounding clean is better than over driving the speaker till it blows. I also bridged mine to cut the resistance in half.
If you want to change the settings on the amp you should turn your favorite music on as loud as you will listen to it and then start changing your gain while it plays. if it starts to destort then you are turning it too high and you should back it down. if you dont think you can do this without ruining what you have then take it to a car stereo shop most of them will do it for free.
Old May 24, 2006 | 04:07 PM
supracrx's Avatar
is the amp i showed only 150 watts at 4 ohms?
Old May 24, 2006 | 04:56 PM
94_DC4's Avatar
Default Re: (supracrx)
Since the amp is 2ohm stable you should wire your sub to 2 ohms to get the best result. If you wire it at 4 ohms then the amp is not going to perform as you expected. I would set the gain to 3/4 and the x-over point to 80hz to break in your sub. And set the bass boost to 1/4. Try that and find out how it sounds.
Old May 24, 2006 | 07:07 PM
supracrx's Avatar
well i thought the amp was capable of 4 ohms at 300 watts..but when i look around the web for more specs doesn't seem rite..hmm
Old May 24, 2006 | 08:10 PM
civic_tuned's Avatar
Frequency Response 20-250
Fuse 60 amp
Crossover
Thermal, Short Circuit and Overload Protection
Max Power Output 500w
Power @ 4 OHM 300 x 1 @ 4 ohms
Power @ 2 OHM 400 x 1 @ 2 ohms
Signal To Noise Ratio 115
Battery Voltage Range 10.5-14.4
Bass EQ
this is the info. i got online. So what u can do rewire yur woofers to 2ohms and Whala!! u got yurself 400watts. If yur woofer is 300rms and this would be the the best set up. Now if yur woofer is 300max and then i suggest to keep it 4ohms.
Old May 24, 2006 | 09:05 PM
02 accord's Avatar
Default Re: AMP/SUB question (cynistersix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cynistersix &raquo;</TD></TR><TR><TD CLASS="quote">I run a 556 max watt audiobahn w12t on an amp that max watts at 550. keeping the system sounding clean is better than over driving the speaker till it blows.</TD></TR></TABLE>
Keeping the system sounding clean is done by using an amp that's rated higher than the sub. This will prevent the amp from clipping and taking out the sub. You just have to be careful setting the gain so you don't bottom out the sub and damage it.
Old May 24, 2006 | 11:57 PM
supracrx's Avatar
the jl10w3v2d2 is either wired in series at 4 ohms, or parallel @ 1 ohms...so what should i do? it was recommended that i run it at 4 ohms so thats why i went that way. how i would tell if the amp is clipping ?
Old May 25, 2006 | 06:08 AM
02 accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supracrx &raquo;</TD></TR><TR><TD CLASS="quote">how i would tell if the amp is clipping ?</TD></TR></TABLE>
You have to put a scope on the output. When it's clipping, you will see the top/bottom of the wave will be flattened. Otherwise, just listen for distortion, but you have to distinguish if the distortion is coming from the amp or the sub.
Old May 25, 2006 | 09:05 AM
mhart's Avatar
run it at 4ohms. dont go 1 ohm it will probally fry the amp. also i dont think the sub can handle much more then 300
Old May 25, 2006 | 09:38 AM
supracrx's Avatar
ok the amp is only rated at 150 at 4 ohms....
where can i find a cheap amp that can power close to 300 watts?
Old May 25, 2006 | 09:53 AM
supracrx's Avatar
would a pioneer GT5200 be good for this sub?
its rated at 380 watts @ 4 ohms.....let me know thanks
Old May 25, 2006 | 11:21 AM
go with hifonics, memphis, phoenix gold,soundstream, jl audio
or others that will do the trick like mtx, kicker, punch, ma audio
Old May 25, 2006 | 12:40 PM
Default Re: AMP/SUB question (02 accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">
Keeping the system sounding clean is done by using an amp that's rated higher than the sub. This will prevent the amp from clipping and taking out the sub. You just have to be careful setting the gain so you don't bottom out the sub and damage it.</TD></TR></TABLE>
I like to keep my speakers for more than 3 years so keeping it reversed and using over 300watt rms'd rated amps and subs lets me do that without distortion. granted if i turn it up to the highest volume on my stereo it will destort but not before my ears start to hurt.
imadigitalgod
Audio / Security / Video
18
May 13, 2008 04:00 PM
deerman2701
11
Feb 14, 2008 05:27 PM
lickety_britches
Aug 9, 2007 01:31 PM
Orpheus1985
Jul 21, 2005 07:15 AM
King_j
Aug 17, 2003 05:05 PM
