SHG is back! Easy's EP3 goes under the knife...
Old 06-28-2012, 07:05 AM
  #2276
mattrt09's Avatar
Default Re: SHG is back! Easy's EP3 goes under the knife...
Great work and execution but man it's a mind **** looking at that picture, im so used to seeing the stock steering wheel right up against the column. I know as long as it serves the purpose it was designed for then who cares but man it looks crazy.
I'm sure it only looks strange because i'm so used to the original.
Old 06-28-2012, 10:04 AM
  #2277
circa86's Avatar
Originally Posted by AllMotorDan
the wheel looks soo far from the other plastic on the side view... there was no way to make it closer huh?
That is the whole point! I hope Evan doesn't get docked any points at all the car shows he spends so much time at hard parking. . .
:thumpup: So well executed sir. Would love to see this car in action in the twisties someday.
Old 06-28-2012, 12:36 PM
  #2278
Spongebrad Squarepants
Egezzy's Avatar
By twisties, you mean the track? I normally keep the twisties on my bread bag.
Old 07-01-2012, 03:14 PM
  #2279
SHG_Mike's Avatar
Some shots I grabbed of Sleasy_E's car at the Black Japan meet and after around the park...
Old 07-01-2012, 11:15 PM
  #2280
Loganej8's Avatar
Dope photos dude.
Old 07-02-2012, 04:47 AM
  #2281
eflove's Avatar
Was good to see another MX-5 and meet you (quickly) this weekend. Hope you guys make it out to Indy.
Old 07-02-2012, 09:19 AM
  #2282
SHG_Claudio's Avatar
The EP3 is getting to that point where everything is built and Its awesome to enjoy all that hard work. Even though it still needs a lot of test, tune, refining an so on, it's already a strong performer as it. Let's see how's going around the track the fastest come August!
Old 07-02-2012, 09:45 AM
  #2283
be water, my friend
metaphor51's Avatar
Loving the photos!
Old 07-02-2012, 09:46 AM
  #2284
SHG_EasyE's Avatar
Are you with the CJ Wilson team? We had a bit of a disappointing run last weekend, engine failure after 10 laps . Rough since it was one of 2 races we had scheduled for the season and lost a shot at one of them. Was still a great experience being at Grand Am as always though, hopefully we will make it to LRP.
Old 07-02-2012, 01:47 PM
  #2285
eflove's Avatar
Yeah i'm with CJWR. I didn't want to pry too much but the car looked nice and clean.
Old 07-02-2012, 03:44 PM
  #2286
skipunk4's Avatar
Pics look great man
Old 07-02-2012, 04:49 PM
  #2287
SHG_EasyE's Avatar
Cool, thanks man. We put alot of effort in making our cars look presentable. A car not only should be fast, but it should also look proper
Your cars look really good with those 9's. We built our car in 08, a year before I started so I had no say in the wheel choice
Old 07-02-2012, 11:46 PM
  #2288
dingo ate my baby's Avatar
boss as evan
Old 07-03-2012, 11:17 AM
  #2289
Egezzy's Avatar
Originally Posted by SHG_Mike
Nice shots, Mike. This one, I think, "Run Forrest, Run!!!"
Old 07-03-2012, 11:18 AM
  #2290
Egezzy's Avatar
You have to let me know, if you are coming to Indy. I am streaking during the Fan Walk, just a heads up!
Old 07-03-2012, 11:56 AM
  #2291
SHG_Mike's Avatar
theinks
Old 07-03-2012, 03:31 PM
  #2292
SHG_EasyE's Avatar
More setbacks :/
Upon assembling the mainshaft I could barely turn 3rd gear, and 4th and 5th had more drag than they should. After a chat with James at Gearspeed, he said I most likely have one of the first sets of their 2nd gen carbon synchros that have issues with tight clearances. They have since revised the design so Im sending my 3-4-5 syncs in and having them replaced with revised parts totally free of charge.
I also need a mainshaft holder tool for setting thrust clearance and to wait on it may be up to 2 weeks
Does anyone have one I can borrow/rent? Ill need it asap, early next week.
Old 07-03-2012, 03:52 PM
  #2293
HatchVX's Avatar
You can use an old clutch disk
Old 07-04-2012, 08:05 AM
  #2294
SHG_EasyE's Avatar
I dont have an old clutch disk, until I take my 5speed out but that doesnt really help.
Youd need to do a bunch of work to it too, no? Split it down the middle then I guess use vise grips to clamp it to the mainshaft...
Old 07-04-2012, 11:32 AM
  #2295
HatchVX's Avatar
All i do it take the old clutch disk and put it on the main shaft and drill a hole to use a screwdriver to hold it in place.
Old 07-10-2012, 11:14 PM
  #2296
SHG_EasyE's Avatar
Once again putting an update together in the middle of the night cause its the only chance I get!
So Ive been keeping myself plenty busy, between trips to NY every weekend to take care of some personal stuff, and getting in any spare time I have on the hatch to get some much needed things done.
Worked on her last friday and bled the brakes with my girlfriend, washed the wheel wells and susp, then did an oil change. Put in about 4 hours
Brakes got bled just as a double check before the next track event, turns out I got a couple little air bubbles from the LF.
Heres a quick look at my new hood prop as well. I picked up an RSX prop and mounting clips since the old prop interfered with the new PS pump. The RSX pivots from the driver side instead of the passenger, therefore it clears the pump with plenty of room.
I had to make new holes for the pivot and retaining clips, as well as cut, clock, and shorten the rod. All said and done it looks and works just like OEM.
Sorry, didnt get any pics of the process...
So after the bleed and wash I got her on the lift to do the oil... (bled the brakes outside so I could wash everything while the wheels were off)
Once again some Castrol synthetic and banded S2K oil filter. I plan on running Hamps in the future since the Toyo Roki S2K filters are impossible to find now. Unless some dealer somewhere has some old stock, it seems all Honda filters are now made by Filtech aka Fram/Honeywell
Heres my little makeshift funnel... screws into the oil cap threads perfectly. Ive been using this thing for about 6 years
Buddy Club exhausts are like a fine wine, they get better with age
Last but not least I got my new front tires in today. I had been keeping a close eye on my fronts because I knew they were getting thin on the inside. After 2 back to back trips to NY the driver side broke through to cords
I ended up getting 23k miles and 2 track days out of them, with about 4/32 tread left. Not bad for a pair of tires that were never rotated
Glad to have new rubber up front, but man, I miss the sharpness of the old tires. Tread squirm on the freshies is definitely apparent, but also does take away a tiny bit of harshness
Gonna be flipping my rears side to side tomorrow to even out the wear
Old 07-11-2012, 04:43 AM
  #2297
SHG_Mike's Avatar
doing maintenance is always the best
Old 07-11-2012, 06:36 AM
  #2298
gabebauman's Avatar
http://i159.photobucket.com/albums/t...e/P1110644.jpg
So great! I use an old Sam's Choice water bottle...but never thought about something that actually threads into the oil filler cap threads. What bottle do you use?
Old 07-11-2012, 06:44 AM
  #2299
<StevieG>'s Avatar
I cant wait for maintenance.. I got the em2 sway and type-r performance rod going on.. new enlinks, oil change.. ganna be fun.. looking good
Old 07-11-2012, 10:34 AM
  #2300
Michael_[UR]'s Avatar
this shot is awesome
good work again
Quick Reply: SHG is back! Easy's EP3 goes under the knife...
